XM Newbie
Re: XM Newbie
Not sure why the Lhm reservoir level affects anti-sink. I wouldn't necessarily suspect the anti-sink valves to be the culprit for sinking, but would check the amount of fluid flowing from the front and rear Hydractive electro-valves. Pull off the return pipe and observe fluid flow. There should only be a squirt as the valve changes state, continuous flow indicates internal leakage, which depending on the state the valve is in, is either the pintle seat is worn, or more likely a rubber O ring has split.
There are two bulletins relating to Hydractive-2 rapid sinking and slow to rise, in the Hydractive training material thread viewtopic.php?f=13&t=10291
Member, xantia_v6 would probably be best to advise on whether the electro-valves can be removed from the stiffness regulators without either subframe, or hydraulic block, removal.
If the sunroof fault isn't the actual switch, or connections then the roof unit needs servicing, which means removing the cassette from the roof.
The glass cartridge is adjustable for height, but the issue is the complete cassette will have sunk on it's mounting brackets. Sunroofs are heavy.
EasyRider
Re: XM Newbie
Thank you for the fast response Dieselman
Biggles1957
Re: XM Newbie
Don't forget you need to check the level with the engine running and suspension at high. If you check it any other way the reading will be miles out and appear to be over filled!
Re: XM Newbie
As far as sinking is concerned, the front and rear suspension are totally independent of each other, can you be a bit more specific of the symptoms? Is it settling right down to the bump stops overnight?EasyRider wrote: Sun Jun 21, 2026 8:18 am Thanks for the replies.
Few issues:
1. The car is S2 but tends to sink overnight. No obvious leaks of LHM.
A leaky electrovalve should not cause sinking (assuming that the hydractive valves are the original type), as the electrovalve is supplied from the primary circuit before the antisink valve.
Re: XM Newbie
I used to think that, however there is a Citroen bulletin referencing exactly that issue, saying it is leaking electro-valves. (Attached)xantia_v6 wrote: Sun Jun 21, 2026 7:28 pm
Another item to check would be the brake Doseur valve isn't sticking slightly activated, allowing primary system fluid to return to the reservoir. We had a member with a rapidly sinking front end caused by the Doseur valve.
Checking the return pipes for flow will reveal the culprit.
Re: XM Newbie
I think that the first linked document is misleading, the "especially if the vehicle is not equipped with anti-sink suspension" seems rather ambiguous. It would not be the only time that a Citroen tech writer glossed over details that he didn't fully understand.
The electrovalve definitely gets is feed from the main supply. I have had Xantias with very leaky electrovalves (the needle valve not a broken o-ring) which did not sink, they were just very reluctant to open the hydractive valve.
The modified hydractive blocks as fitted to late Xantias do have the electrovalve fed from the suspension circuit, and (for a couple of reasons) they are more inclined to sink over the course of a few days.
Re: XM Newbie
I think what is being said is that the fault can affect either anti-sink, or sinking cars, but the effect is more pronounced in sinkers, as all components leak a little and once the car sinks at all the height corrector opens to admit more pressurised fluid and there isn't any, so it then sinks quickly.xantia_v6 wrote: Mon Jun 22, 2026 11:20 am I think that the first linked document is misleading, the "especially if the vehicle is not equipped with anti-sink suspension" seems rather ambiguous. It would not be the only time that a Citroen tech writer glossed over details that he didn't fully understand.
An Smac (anti-sink) car blocks the feed from the height corrector, thus has no further effect, even if calling. It also has the sphere to provide a reservoir of pressurised fluid.
My thoughts are that suspension feed pressure is marginal due to the leakage, so it rises slowly and there is no reserve when the engine is switched off, thus the car sinks quickly, even with the Smac valve closing.
I suspect a car exhibiting this issue would struggle to raise if loaded with significant weight.
EasyRider
Re: XM Newbie
OK I found the O/S Suspension return rubber pipe had broken and fallen off. Are these available and same for all XMs?
Cheers
Cheers
Re: XM Newbie
The hose is P# 95050399
The clip is P# 96127591
Do both sides as if one hose is perished, the other won't be far behind.
If the clips are still the original stainless steel click-clips, then you can re-use them. If they are aftermarket ones, you will need to replace them.
Re: XM Newbie
The hoses and clips are still available via the Citroen classic parts service (and maybe from dealers), but are also on eBay and several after-market sources at various prices.
If you don't have the right pliers to fit the clips, I found that it becomes easier if you put a couple of strong zip ties around the hose cup and the metal clip and tighten them to compress the cup and reduce the tension required to fix the clip, the zip ties can then be cut off after the metal clip is clipped..
