1992 2.1 Sd Auto Estate
Re: 1992 2.1 Sd Auto Estate
Post by Dieselman » Tue Nov 04, 2025 7:35 am
Thinking back over the days work made me realise I hadn't fitted the regulator hydraulic hose retainer bracket under the aforementioned missing bolt: quick job, undo the bolt, install the bracket, refit bolt.
The water pump arrived so it was on with timing belt and water pump removal.
As expected the bolts were all seized in and as they screw into the aluminium casing I was very careful to work them out gently, with plenty of lube and loosening and tightening repeatedly until they were free.
I didn't have any taps, or dies, so spent some time cleaning the bolts and casing threads until the bolts could be screwed in by hand only. When fitting I added a trace of copper-slip to avoid any further corrosion issues.
When the pump was removed half the gasket was very stuck to the housing, so I cut it off with a knife blade, then wire bushed, sanded and scraped the face until clean.
Fitting the new pump and gasket is straightforward, though it's useful if you apply non-setting sealing compound to stick the gasket to the water pump to hold it in position.
I fitted this one dry, so it was a bit of a fiddle to ensure the gasket stayed aligned. I didn't want to use grease as the gasket is meant to bond to the metal surface.
Interestingly, the pump being removed is a genuine Citroen one. I can't work out whether it is September '92, or September '02 manufacture. September '92 would correspond with the manufacture of the car.
The timing belt and engine mounts are all back on, awaiting adding coolant.
Post by Dieselman » Wed Nov 05, 2025 7:55 am
Coolant added, engine run to temperature and bled of air, also changed the gearbox ATF, which is very worthwhile and should be done every 12,000 miles.
From under the gearbox you access the strainer and drain plug.
To remove the strainer first unbolt the outer cover, then using pliers without serrations, pull the strainer down using one of the support legs. They can be quite stuck in, but keep firmly pulling while wiggling it a bit.
The old ATF was dark brown, but didn't smell of burning.
Clean the strainer using petrol, or white spirit, and a brush. this one was surprisingly clean, with not much debris and no metal flakes.
Fit new O rings to the strainer and cover; strainer is 49 * 2mm, cover is 50 * 3mm.
My new O rings were 2.5mm and 3.5mm cross section, and I couldn't make the strainer O ring fit without risk of breaking the strainer, so re-used the old O ring this time, which was still a firm fit.
The drain plug uses a 16mm copper/aluminium washer as the seal.
The gearbox took 3.5 litres of new ATF and appeared at the 80c Max mark, when hot. I'll check it again when in use and fully hot.
to check, run the selector through all the gears, put it back in park, leave the engine running and pull the dipstick.
ATF expands significantly when hot, so the dipstick is marked with 40c and 80c markings.
I pulled the rear wheel arch liners out, wire brushed the dirt out and had a look at body condition. There are four small areas to weld: front wheelhouse outriggers, left rear inner sill, one small patch on left under the car.
The rear of the car is in very good condition, especially for an estate.
There are some areas of damage to the floor and sills, mainly where the car took a bit of a beating when being moved while not running.
Post by Dieselman » Sun Nov 09, 2025 9:57 am
There was a hump in the carpet at the rear left; stripping out revealed the floor has suffered significant damage from being jacked up with a trolley jack,
So far I've stripped the seam sealant and stretched and knocked the floor and upright back into shape. The seam has pulled some spot welds out so I will weld that.
The rear right sill has a large deep scrape, presumably from running up a high kerb.
I drained the tank and removed the fill pipe, which due to being 10mm too long was rubbing on the inner sill, causing corrosion, capped the tank spigot, cut out the very small amount of inner sill corrosion and set to re-forming the outer sill.
As the sill is now corroded due to the damage there is no point attempting paint-less dent removal, so I welded tags on and used chains as pullers.
My intention is to reform the sill to the original shape, then cut out and replace any corroded/weakened metal.
Post by Dieselman » Wed Nov 12, 2025 7:46 am
After re-forming the outer sill I cut the rotten metal out which revealed an intact inner sill and jacking point. Often these are significantly corroded.
Post by Dieselman » Sun Nov 16, 2025 9:52 am
A bit more hot stick and hammer action and the right sill looks a bit like...
The inside had a tiny bit of corrosion and also I filled over the alignment hole with metal instead of the factory installed seam sealer.
The left sill had a section needing replacement on the inner side of the jacking point. After cutting the plate off it became apparent there were leaves inside the sill and the outer skin was also corroded.
Another bout of Mr Angry Grinder.
Poking about in the seam sealer in the rear wheel-house revealed a water entry point.
Inner side seamed and puddled on.
And outer parts too.
As a precaution I took the fuel filler pipe out of the right side wheel-arch, but all seems ok there.
Rear passenger floors both straightened, one welded and straightened again.
Half way along the left sill was a nasty gash where the metal was very creased inwards.
A bit of tag and chain action saw it basically straight, but the metal was thinned and needed replacement.
Post by Dieselman » Sun Nov 23, 2025 4:45 pm
The longitudinal chassis rails under the cabin floor had some rot where they join the inner sills and a fair amount of dirt was packed inside.
The right side one was markedly worse than the left.
Angry grinder and hot stick to the rescue.
Left side...note another jack pad crease.
A patch made from one piece of new metal. I had to slit and weld it where the rail steps up as hammer forming such a complex shape was not possible...for me.
Right side was worse so the complete rear part of the rail was replaced with new metal, including letting a reinforcing patch into the cabin floor, where it joins the sill, which was welded from above and below.
The full process was to cut out any rot, fabricate and weld in an L shaped reinforcing patch then create a single piece vertical sides piece that looped round the rear end: this was welded to the original rail and the cabin floor, whereas the original was only welded to the floor on one side of the rail.
Next a flat piece was joined to the rail side and sill and closed at the front end.
Lastly a shaped cap was formed to cover the underside of the U shaped rail.
There was a hole in the front silencer pipe.
The holes in the floor where a fire extinguisher had been screwed down with a 60mm self tapping screw was filled
The front wheelhouse transverse sections cut out and plated.
The alignment hole through from the sill that lets water through once the seam sealer breaks down was plated over, adding strength to the jacking point in the process.
onza100
Post by onza100 » Mon Nov 24, 2025 3:59 pm
Some lovely work there.
Post by Dieselman » Tue Nov 25, 2025 7:07 am
Thanks.
Time is the limiting factor in tidying these repair's up further. This is a return the road project, not a restoration.
Post by Dieselman » Thu Nov 27, 2025 6:58 am
I wasn't happy with the rear edge of the longitudinal chassis rail on the right side having flexed away from the rear cabin floor, so rather than just apply new seam sealer I scraped out the seam sealer inside and out, pressed the rail into place and welded it back again.
Access was a bit poor with the fuel tank still in position, but using a metal plate as a protector worked ok.
Post by Dieselman » Sun Nov 30, 2025 11:27 am
latest progress.
Painted the inside floor after welding, straightening and seam sealing, the underside where welded and underseal was damaged. All areas received de-rusting, scrub with mild acid, wash, seam sealer, anti-corrosion primer, and a couple of coats of either white, or black paint.
The fuel and hydraulic pipes are now clipped back into place and covers installed and the rear subframe is now bolted up.
Interestingly the estate appears to have more hydraulic pipe covers than the saloons and these are specially made by Huliez and additional body fittings are welded to the floor to accept them.
Refitted the fuel tank filler neck and connecting pipe. I cut 10mm off the pipe to ensure a clearance between it and the inner R/h sill.
I removed, cleaned up and painted the strut tops, though did manage to mark the upper side paint while using a die to clean the mounting stud thread.
I tipped about 15 litres of diesel back into the tank, pumped the primer about 40 pumps and turned the key, at which point the engine fired up on the first attempt...without any hydraulic leaks also...double bonus. :)
