1994 VSX CT auto BREAKING
Southerneruk
Re: 1994 VSX CT auto BREAKING
Post by Southerneruk » Tue May 07, 2024 1:19 am
So long as they are kept together firmly and no air gets in between the glass plates should be ok
Post by Dieselman » Tue May 07, 2024 6:40 am
Citjon wrote:
Mon May 06, 2024 12:20 pm
Southerneruk wrote:
Wed May 01, 2024 9:55 am
Do you still have the 2 led open doors & fault and clock either side of the steering wheel
I've tried adding photos but keep getting an error message, so will pm you.
The clock display is quite dim but looks to be OK. The screen on the left message display is scratched but the digits look complete. I'm not sure if it could be changed or maybe polished out?
Forum attachments are an issue at present, unfortunately you will need to externally host then link to those.
I believe southerners car is a Series1, whereas the VSX is a series 2. The left display is not the same. The basic clock/temp display is.
Southerneruk
Post by Southerneruk » Tue May 07, 2024 9:09 am
umm while I remember, do you have the under the bonnet relay holders, could do for one of those
Citjon
Orga / RP numbers: 8032
Post by Citjon » Tue May 07, 2024 2:25 pm
Do you mean on the slam panel at the front? If so yes I still have those.
89 CX25DTR T2
72 D Super 5 Black
72 DS21 efi Bleu D'Orient
Citjon
Post by Citjon » Tue May 07, 2024 2:27 pm
This car has the trip computer fitted
89 CX25DTR T2
72 D Super 5 Black
Southerneruk
Post by Southerneruk » Wed May 08, 2024 12:15 am
My car don't have the trip computer fitted. Mine is indeed a series 1 so it looks like they will be no good to me, But those relay holders will be useful, there is one on each side, holds 4 relays in each, they are riveted or bolted to the panel above the lights
Citjon
Post by Citjon » Fri May 10, 2024 5:56 am
TomSaintJames wrote:
Mon May 06, 2024 9:09 am
Citjon wrote:
Tue Apr 30, 2024 3:35 pm
Hi Tom,
All those parts are still on the car but I have had an enquiry from someone about the complete engine.
If that doesn't come to anything I will let you know and I'll look into postage costs etc.
Many thanks,
Jon
Any update on this Citjon?
Hello Tom
I've had some interest in the bare engine so the parts you wanted will be available soon. I don't mind getting them packaged up for posting. Would you like to pm me your address so I can confirm the cost.
Regards,
Jon
89 CX25DTR T2
72 D Super 5 Black
TomSaintJames
Post by TomSaintJames » Fri May 10, 2024 8:51 am
Ah excellent! Thank you Jon, I will PM.
wesacosa
Post by wesacosa » Mon May 13, 2024 8:22 am
Hi
Do you have the little clips that hold the door glass into the frame ? Mine are either broken or missing so the windows drop into the doors when I operate them so looking for some spares
May also be interested in the passenger front window regulator if thats working too
Cheers
1997 2.1 TD Manual (XUD11BTE, RP7367). Slowly getting it brought back to life
Citjon
Post by Citjon » Mon May 13, 2024 9:14 am
Hi Wes,
The clips should still be attached to the windows, so yes in theory I should have some. It may be a while before I get round to looking though as I need to remove the engine for someone first.
Neither of the front windows work at present but I guess that is probably down to faulty switches or a bad connection somewhere.
Jon
89 CX25DTR T2
72 D Super 5 Black
