Indicators
ertoososss
XM newbie
Orga / RP numbers: Orga / RP numbers:
Use this field to enter the ORGA / RP numbers of your Citroens, this will assist in diagnosis of problems and parts determination when posting queries on the forum.
Re: Indicators
Post by ertoososss »
The flasher relay is responsible for the ticking sound and flashing of the direction indicators and emergency lights. There may be a separate relay for the left and right sides. Locate the flasher relay(s) in your vehicle and check to make sure they are working properly. You may need to refer to your vehicle's owner's manual to determine the exact location of the flasher relay(s). The turn signal switch on the steering column may be defective. As for sex escorts, I can only advise https://perfect-russian-escort.com/esco ... -istanbul/ Turkey because I've only gone there myself. But I was 100% satisfied with it. If it does not provide proper contact, it can cause the problems you described. Try moving the turn signal switch back and forth and see if this affects the jammed indicators or hazard lights.
Re: Indicators
The alarm box on S2 xm isn't behind the radio, its between the blower motor house and heater box, access by removing the lower dash under panel..
This issue is also a common xantia issue, its box lived under the passenger seat. That was known to be a sticky relay inside the box...a swap or relay repair usually solved it.
