V6 Si, what have I done????
Re: V6 Si, what have I done????
What sort of value is a manual box? Are the linkages etc readily available? They were rare for Mercedes, especially 6 cylinder cars.
Linkage rods will be rare .. and if there are any.. which id likely have.. the nylon ball pops would be worn and would benefit from refurb if its possible.
If it’s ok with you I’ll see how the car goes initially in terms of how sound it is, and then I’ll look seriously into the conversion..
Thank you for your help so far
The manual gearbox is a ME5T, which is fitted to all manual Xm apart from 2.0I atmo petrol, 2.1 Atmo diesel, 2.5Td, later 3.0i Es9j engine.
I would think finding a complete clutch cable will be more tricky than finding linkages.
The clutch cable has a bespoke bell crank assembly only fitted to Rhd, Xm, however installing hydraulic clutch pedal is possible and is the route I would take if doing this from scratch.
Pedal box from a 2.5td, bespoke slave cylinder to the clutch release arm.
Thank you Dieselman, are you the same Dieselman who used to be on the Mercedes Forum?
Well, she made it home from Camberley to Devon along a very busy A303 yesterday evening.
Boy, what a car, it never felt 32 years old, was fast and very very smooth, I was very impressed. There are lots of similarities with the Mercedes 124, quiet, relaxed, easy to drive and no rattles. Plus the little visor above the rear view mirror.
It wasn’t completely incident free so I’ll start another thread if I can’t find a solution to the isolated jearky throttle when it was in slow traffic.
Quelle surprise...StevenPerry wrote: ↑Sat Sep 10, 2022 7:08 amBoy, what a car, it never felt 32 years old, was fast and very very smooth, I was very impressed.
...and the foot operated parking brake.StevenPerry wrote: ↑Sat Sep 10, 2022 7:08 amThere are lots of similarities with the Mercedes 124, quiet, relaxed, easy to drive and no rattles. Plus the little visor above the rear view mirror.
Big Mercs and Citroens share a common theme, they are designed to effortlessley make miles of tarmac dissapear under the bonnet without the occupants noticing.
Have you acquired a copy of the Practical Classics August 2019 executive car shootout, yet? Well worth a read.
Clean the trottle flap, check vacuum pipes to the MAP sensor, check the setting of the throttle potentiometer...<0.5v throttle closed, >4.5v WOT.StevenPerry wrote: ↑Sat Sep 10, 2022 7:08 amIt wasn’t completely incident free so I’ll start another thread if I can’t find a solution to the isolated jearky throttle when it was in slow traffic.
Look for worn out engine mounts.
Make a Blink Code Reader and read any codes: see linked thread.
https://club-xm.co.uk/Forum/viewtopic.php?f=8&t=7368
Thank you!
Yes, I was surprised at the similarities, both super vehicles!
Yes, I have a copy coming, can’t wait.
I’ll have a look at the items you mention, thanks for your help.
- XM newbie
Hi Guys, I know it is an older post, but if I read correctly, I could take the manual gearbox from my 2.1 Turbo diesel and convert my automatic 3.0V6 12valve to manual using the parts from the 2.1 turbo Diesel, in other words the diesel gearbox and clutch should fit on the V6? Thanks, Mark
Both engines mate to the ME5T gearbox, though citroenxm (paul) says the bell housings are different.
You would need to check the gear ratios/final drive ratio. The diesel will be using a longer final drive, but the V6 has a greater top speed, so the two may balance out.
Technically, the V6 gearchange linkage should have a rubber ball section, the Td uses a steel one. The rubber is for a more luxurious feeling gear-change.
From memory the clutches are the same unit.
