XM Virginia USA
Re: XM Virginia USA
Post by Dieselman » Fri May 27, 2022 6:46 am
antonioconceicao wrote:
Thu May 26, 2022 11:17 am
I found a valeo one on ebay will be arriving next month and I will try to make something out of the old one and the new one
Hopefully someone will have the Simplex one you are after.
antonioconceicao
Re: XM Virginia USA
Post by antonioconceicao » Fri May 27, 2022 12:11 pm
I have not located a Simplex one , do you think is possible to use the valeo one with minor changes on it ?
I hope to make it work until I find the correct part
Thanks for the help
Antonio
1992 Citroen XM 2.0l Inj
Vin VF7Y3AC0007AC9679
Virginia USA
Jarvis_C
Re: XM Virginia USA
Post by Jarvis_C » Mon May 30, 2022 8:38 am
Thu May 26, 2022 6:58 pm
Still have some getting repair :lol:
Selling some this year but will replaced with better ones :x
Wonderful. I think it's fantastic to see someone with that fondness for Citroëns there in the United States. Congratulations and good luck with it, those cars look splendid!
antonioconceicao
Re: XM Virginia USA
Post by antonioconceicao » Thu Jun 02, 2022 3:40 pm
I have been fondness for Citroen since little kid btw I just got 3 friends over in the USA a couple week ago and we had a blast driving them
Antonio
Virginia USA
Re: XM Virginia USA
Post by Dieselman » Sat Jun 04, 2022 7:15 am
See thread viewtopic.php?f=8&t=9801&p=125662#p125662
Re: XM Virginia USA
Post by Dieselman » Sat Jun 04, 2022 7:17 am
Antonio
Nice selection of Citroen, Haut de gamme.
antonioconceicao
Re: XM Virginia USA
Post by antonioconceicao » Sat Jun 04, 2022 11:29 am
Thanks!
I hope to get some time to take care of the ignition switch of the XM today
Doing the Cont test on both and I am sure I will figure it out how to wire it .
Trying not fry anything on it LOL
This XM scares me with how many wires got under the dash :lol:
Thanks for the PM
Antonio
Virginia USA
antonioconceicao
Re: XM Virginia USA
Post by antonioconceicao » Mon Jun 06, 2022 12:05 pm
Replacement the originial 8 wire 3 plug ignition switch with a of the CITROEN XM Lock Sets 4162.E8 252418 6 wires 3 plug
I hope this will help someone in future
As said before on the forum requires a small alteration to make it work
The Valeo comes with 3 long wires my originial one had 2 long wires and small wire
Should look like this , I used the original end plugs
troubleshooting
You should have a plug with 2 wires coming out of the fuse box with 12v cont
One wire of the short plug goes to the started (check cont when Start key position) if you feed 12v on the blue car wire starter will kick in
I hope this help someone
Antonio
Antonio
Virginia USA
Re: XM Virginia USA
Post by Dieselman » Tue Jun 07, 2022 7:14 am
Good job, well done and thanks for posting the result back to us.
I have linked your post to the thread regarding this topic for future reference.
antonioconceicao
Re: XM Virginia USA
Post by antonioconceicao » Wed Jun 22, 2022 1:11 pm
Saratoga Spring NY USA, Citroen Event
Last Thursday afternoon I decided to leave on Friday around lunch time to my first road trip with the XM in USA . Cover over 1000 miles in 48 hours, car run really well
With temperatures around 40c I was able to temporaty fix the AC , without any parts available to me I decided to try the old trick , clean the ac system , used the oil for ac systems this time and it worked and then charge it to see what happens .
First time I actually clean a dryer and reuse it again :lol: but at end I had a 60f cold ac blowing on setting #1 and #2 70c #3 setting blowing it worked fine for the trip, not the best but it dry it off the humidity as the inside temperature maybe was around +-78 f
Btw got a new dryer from Uk already and I notice the exp valve is also used on the old mercedes s600 , got a new one from mercedes dealer for a future project .
Antonio
Virginia USA
