New Member From Turkey
Re: New Member From Turkey
Maybe if I put it back together....... But fear not, parts of her will live on, already are working again! And it needed a respray anyway, so there is an idea for you!
Paul are you OK? Considering an S2? My gosh, that was the last thing I ever expected to hear you saycitroenxm wrote: im sooooo wanting a black xm and they are not that common. Ill even consider an s2
Ahhhhh BUT I have a spare S1 dash, so Id rif that horrid excuse of a S2 dash and fit the S1 Proper dash...
What is the difference between s1.5 and s1?
Current Cars
1996 Citroen XM Turbo CT VSX AUTO
2000 Citroen Xantia Activa 2.0HDi
Used to Own
1995 Citroen Xantia 2.0i Sx
2000 Citroen Xsara 1.6i 8v Sx
2001 Citroen Xsara 2 1.6 16v Sx
Used to Own
Urrrmmmm... externally very little to nothing..the door mirror GLASS is bigger and fills the Casing..
the rest is under the skin. Earth points are bolted, the suspension ECU has better parameters and so the suspension is more likely to work correctly, a twin spoke steering wheel was fitted, the Main Headlight switch moved from the roatry switch on the steering cowling to the indicator stalk in the form of a slide switch, and cruise control was added to SEi Spec cars..
These are the main visual differences, so unhidden ones I dont know fully..
Interesting. Are there s2.5 too or s2 is the last one? Why do you prefer s1 instead of s2?citroenxm wrote:Urrrmmmm... externally very little to nothing..the door mirror GLASS is bigger and fills the Casing..
Current Cars
Used to Own
Used to Own
Better spoiler, better more "Airey" spacious cabin due to a lower dash, I think the S2 dash Looks TOO plasticley and cheap, Hydractive 2 is a pain sometimes, though there are fix's so thats not a vaild point of mine... crap stupid lip spoiler on S2., LHD displays ALWAYS work on S1 cars, again there are fix's are S2 ones and they are not directly compatible. A Stupid half flap over the radio instead of a full size one..
I like the look of s1 exterior much more. But I like s2's interior. I am planing to convert my car's exterior to s1. Do I have to change the headlights for front panel between the headlights?
Current Cars
Used to Own
Used to Own
Totally agree with all that. Why I prefer S1..... Better looks.
The grills are cross compatible... however, the front bumpers are also different, in that the front fog/indicator lamps are much larger and are bolted behind the bumper, and the S1 Fog/Indicator lamps are smaller and push and clip in..
