Hello Chaps....new owner
Stickfinger
Re: Hello Chaps....new owner
Post by Stickfinger » Sun May 09, 2021 5:53 pm
Re-seating the swirl chambers is part of skimming these heads....so that will be done to give the correct protrusion and correct the angle.
Stickfinger
Post by Stickfinger » Mon May 10, 2021 2:38 pm
And........I now have 4 very stuck copper injector copper seals.
Very stuck, screwdriver and hammer not working..........any ideas ?
Post by citroenxm » Mon May 10, 2021 2:42 pm
I must say I've never changed idi injector seals.. Never had issues with them like some do with modern Di injectors.. But it's up to you.
Post by White Exec » Mon May 10, 2021 3:55 pm
Good soaking with PlusGas? Maybe some freezer applied as well?
Stickfinger
Post by Stickfinger » Tue May 11, 2021 8:15 am
Tried soaking, tried cold, tried hammer/screwdriver.....they are very stuck. A job for the machine shop then, as I will only end up damaging the seat.
Stickfinger
Post by Stickfinger » Tue May 11, 2021 1:13 pm
Decided not to be a defeatist :)
After lots of faffing about being gentle I decided hitting stuff hard can be a good thing :) So I set about bashing the cr## out of the washers.
This is what I had, not the copper has flowed into/under the lower threaded area, compression, heat & time.
I took a thin but blunt metal screwdriver and cut 90deg to the washer, rapid tapping rather than hammering "pushed" the copper out of the way.
I made two cuts at 90deg the width of the screwdrivers blade apart.
A third "cut" I made at the back, this goes in a lot easier, so again lots of gentle taps with a big hammer
This moves the chunk
Pushed out completely
A few taps at the edge now allows the washer to bend releasing it
Out.
Stickfinger
Post by Stickfinger » Tue May 11, 2021 1:30 pm
What "faffing about being gentle" gets you
Conclusion = HIT IT HARDER
(I will say this until it is broken)
Post by citroenxm » Tue May 11, 2021 2:00 pm
Yes sometimes they need a bit of rough n tough..
Well done
Stickfinger
Post by Stickfinger » Tue May 11, 2021 2:55 pm
Help me ID these seals, washers etc.....I am assuming the seals are crank shaft and camshaft ? Not even a clue what the washers No2 & No3 are
Post by citroenxm » Tue May 11, 2021 3:44 pm
2 n 3 are what go into the injector nozzle port.. Fire proof seals I think. Not sure why there's two sets..
