Think you've spied another forum member's XM out on the roads? Ask in here!
								sageman
						Post
								by sageman » Sun Jan 26, 2020 7:36 pm
									1976 Reliant kitten
1998 Peugeot 306 GTI-6
1993 XM sei V6 RP 5876
						Post
								by citroenxm » Sun Jan 26, 2020 7:41 pm
			Have gone for scrap or defo rescued..?
						Post
								by citroenxm » Sun Jan 26, 2020 7:42 pm
			Single spoke leather coated wheels have some value now too...
								sageman
						Post
								by sageman » Sun Jan 26, 2020 7:43 pm
			No defiantly rescued the scrap man is kindly storing them for us
									1976 Reliant kitten
						Post
								by citroenxm » Sun Jan 26, 2020 7:46 pm
			Ah OK.  Shame of the body damage. . Remove the oil filler and look in side.. I've posted on previous page the difference between good and bad rocker gear..
						Post
								by MTXM » Sun Jan 26, 2020 7:46 pm
			Thanks for uploading photos of the engines Paul that I was going to do myself!  As you will note the early engine rockers are grey (aluminium) and later orange (steel with oil staining). As already mentioned both my 24v engines have steel rockers and hence are still alive and kicking after 120K!  The only car we know that broke the rules was David Hallworth's Green 'J' Plate, which somehow survived past 100K.  Best regards, Matthew T.
						Post
								by MTXM » Sun Jan 26, 2020 7:47 pm
Yes we did indeed check Paul and both engines have orange (steel) rocker gear as mentioned above and are therefore later engines. With regards, Matthew T.
						Post
								by citroenxm » Sun Jan 26, 2020 7:49 pm
			Ah apologies in my understanding Mathew.  When you said steel rockers i assumed early rockers because I was lead to beleve the modified setup was actually ceramic and not steel ones..
						Post
								by citroenxm » Sun Jan 26, 2020 7:50 pm
			That's a damm shame. The green car now damaged which could have been another good car..
						Post
								by MTXM » Sun Jan 26, 2020 7:59 pm
			That is no problem Paul and I just poached some photos from Darren's earlier thread showing my spare engine and failed steel followers and later ceramic fittings with the orange steel rockers showing alongside. With regards, Matthew T.
MTXM on Sun Jan 26, 2020 8:05 pm, edited 1 time in total.
