Stainless steel clutch mechanism "quadrant" replacement
colinxm
Post by colinxm » Thu Oct 07, 2010 8:25 pm
Hi all, as promised I've replicated the crappy, plastic quadrants in 316 stainless.
These will outlive the life of the car ;)
Anyone that wants one please send pm including name and address to post to. Price will be £25.00 plus postage, this might sound a little steep but I've used a considerable amount of time in producing these.
Cheers, Colin.P
1995 Cit XM 2,1 TD Silver Estate - deceased :-(
2004 Opel Vectra Estate
2008 Kia Ceed td
1989 Pug 205 Cabriolet
1998 Ford Puma
1979 Triumph TR7
Ciaran
Site Admin
Orga / RP numbers: 1234
5678
91011
Re: Stainless steel clutch mechanism "quadrant" replacement
Post by Ciaran » Fri Oct 08, 2010 11:36 am
Whats it do? :oops: :oops:
Post by XMX » Fri Oct 08, 2010 11:55 am
Ciaran wrote:Whats it do? :oops: :oops:
Hi Ciaran,
It's a replacement for the cheap/poor, nylon/plastic bell-crank that's part of the clutch cable assembly that take's the cable thro' 90 degree's at the bulkhead entry that often fail's on a manual car which are cable operated, (that's another reason for having 2.5 TD, as there hydraulic) see THIS thread for more info !
:D
Ciaran
Site Admin
5678
91011
Post by Ciaran » Fri Oct 08, 2010 11:57 am
Aha the famous plastic 'clutch clip' you used to hear non-Citroen fans ranting about.
Cheers for the explanation :D
Would they fit the Xantia Colin? You might be on to a nice little earner here......
Ciarán
kenhall
Post by kenhall » Fri Oct 08, 2010 2:59 pm
Is there a problem with the PM and email system? I have tried to contact Colin re buying a quadrant but it appears that the messages have not gone.
Colin - have you received anything?
Ken
messerschmitt owner
Post by messerschmitt owner » Fri Oct 08, 2010 3:08 pm
Ken
PMs working OK
mine went through - awaiting confirmation from Colin and payment instructions.
Image[/url]
Ciaran
Site Admin
5678
91011
Post by Ciaran » Fri Oct 08, 2010 3:37 pm
Hi Ken,
Should be working, do you get an error message or timeout or anything, or does the message go but Colin appears not to get it?
I'm going to send you a test PM now, see if you can reply to me :)
Ciarán
Post by robert_e_smart » Fri Oct 08, 2010 3:57 pm
Hi Ciaran,
The Xantia suffers from a different clutch cable clip failure. The clip that attaches the cable to the pedal often breaks.
Post by Dean » Fri Oct 08, 2010 5:55 pm
Colin, that is a work of art 8-) but unfortunatly im an auto man ;)
Citroenesque
Post by Citroenesque » Fri Oct 08, 2010 9:28 pm
If you can wait a bit, I'm up for it... so to speak :oops:
