Everyday XM?
jonathan_dyane
Re: Everyday XM?
Thanks
Jonathan.
2004 Saab 9-5 Aero Estate
1999 Yamaha FZS 600 Fazer
1991 Kawasaki GT-550
1986 MZ ETZ 250
1986 MZ ETZ 250
kingp
Re: Everyday XM?
Dieselman wrote:If you can't find the leak clean the pump then coat with talcum powder or flour and run it. The leak will soon be obvious.jonathan_dyane wrote:I guess the old girl does deserve another chance although the cursory glance little time permitted earlier didn't reveal where the leak was emanating from only that it seems to be dripping from the underside of the pump so likely not the drive shaft seal which is good...
Exploded image of the pump. Thre aren't many seals (O rings), one on the rear, one on the front, nose seal, metering head seal, maximum fueling screw seal. A seal kit will contain them all.
http://www.westportparts.com/dieselvw/i ... csPump.JPG" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;"
It possibly is the Bio-diesel that has ruined the seals.
It will only ruin seals if the methanol isn't being fully recovered. Any left in it will eat away at seals.
Veg is similar but there are plenty with high miles on them. Don't forget the car is what 20-25yrs old! Lots of rubber bits will be or have already gone on it like hoses and tyres. The seals in the pumps take a lot of pressure and high heat and then in winter temps well down to -10'c and more like 150'c+ with the engine bay in summer...
kingp
Re: Everyday XM?
Dieselman wrote:This might help.
http://www.ebay.co.uk/itm/CITROEN-XM-2- ... SwaNBUkBxY" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
A full rebuild with warranty is around £250 isn't it?
Being Liverpool way have you tried calling pf Jones in Manchester as they do exchange pumps and injectors and may have one on the shelf for exchange...
jonathan_dyane
Re: Everyday XM?
I think a full rebuild is more like £600 unfortunately, certainly looking at the PF Jones website they list the applicable pump at £660.
Although I haven't touched the car since Friday I've spent some time looking at exploded diagrams and I *think* I might have worked out where I went wrong although unfortunately I think the pump will have to come off and come to bits again to remedy the problem. Hopefully I may have a chance to have a look at it tomorrow. Looking again at the pump on ebay I think this is off a later car and the rheostat device on top of the accelerator lever indicates that it has computerised advance which would make the pump unsuitable to me. I think.
Jonathan.
1986 MZ ETZ 250
1986 MZ ETZ 250
Re: Everyday XM?
Throttle lever position sensor..thats all it is.. However when citroen went semi electronic they dropped bosch and switched to lucas..
Interesting pump that one.. Wonder what year exactly. Its defo a mechanical pump.
jonathan_dyane
Re: Everyday XM?
But what does the sensor do?
Incidentally I've also spent some time looking at alternative (and newer and more sensible) cars and I haven't found anything else I'd rather drive. I might just have to fix it...
Jonathan.
1986 MZ ETZ 250
1986 MZ ETZ 250
Re: Everyday XM?
Isn't that sensor to do with the trip computer?
Going back to a pump rebuild...you're right, they are that much. I know first hand.
Re: Everyday XM?
No.. The bosch cars never got trip. They only got trip when they switch to lucas epic semi electronic drive by wire
nyekk
- XM newbie
Re: Everyday XM?
If I'm not mistaken and we talk about the same item, the throttle lever position sensor on the top of the pump is part of the EGR system. It is used to determine when to open the EGR valve. I simply disconnected mine, it is not part of the pump operation.
Re: Everyday XM?
Ahh, yes of course.
