Michelin CrossClimate tyre
normanlindley
Huddersfield
Re: Michelin CrossClimate tyre
If you fit the Michelin energy saver plus tyres make sure you have a good and accurate tyre gauge as the tyre pressures must be spot on then it will ride very well too high by only a couple of psi will make it bumpy but great tyres i'v had several sets on my old Xm Estate.
Huddersfield Has no sunroof
- Pshemsky
Just one more question about Michelin Energy Saver Tyres+. There are three options T, V and H. Is there any real difference between them? There's small difference in price T- cheapest and H- most expensive. But can't see any difference in tyre itself.
Sent from my D6503 using Tapatalk
Prem
XM 3.0 Exclusive (2000)
Gone with the wind...
Xantia 2.0 HDI (1999)
C5 2.0 HDI (2003)
XM 2.5 TD (1996)
Xantia 2.0 HDI (2000)
Prem
C5 2.0 HDI (2003)
XM 2.5 TD (1996)
These letters are the speed ratings for each tyre. You should fit the correct one - either the owner's handbook or the label on the A-post (door pillar) will detail tyre size and speed rating.
Fitting a lower rating than the correct one for the car can lead to a vehicle test failure.
From memory, the 2.5 is 205/65 R15 V, but check.
Murray
- Orga / RP numbers: RP4768
Hi there,
I fitted a full set to my 1989 2.0 Si over a year ago, they are simply great!
Good grip, silent running, excellent in the wet and really not that expensive for a branded quality tyre.
Highly recommended!
Murray
Highly recommended!
Murray
