help
stan
Re: help
Post by stan » Sat Nov 19, 2016 8:33 am
hello all , thanks for the replies.
its a 3 ltr v6 12 valve.
its full of fuel.
I am going to start looking for the problem on sunday
stan
Re: help
Post by stan » Tue Nov 22, 2016 5:39 pm
hi all.
it looks like the rotor in the distributer cap , I've ordered a new on and will fit it on Friday afternoon after work.
fingers crossed.
but the crank sensor failed and now the rotor has failed, could this be linked
Re: help
Post by MTXM » Tue Nov 22, 2016 7:02 pm
That is good news you have found the problem Stan and I suspect the only connection with the crank sensor is age! Regards, Matthew T.
stan
Re: help
Post by stan » Sat Dec 03, 2016 6:17 pm
I have also replaced the suspension arm return pipe on both front wheels as I am sick of topping up the oil
Re: help
Post by White Exec » Sat Dec 03, 2016 7:36 pm
They do eventually split with age. I guess most of us have had to do that job! Pipes and clips still available, and same as Xantia, if I rememember rightly.
Did you manage to sort the other problem?
Re: help
Post by citroenxm » Sat Dec 03, 2016 8:40 pm
Strut returns same as C5 too.. but they are just a bit longer so easy to cut down..
