Great minds think alike.....Dean wrote:The best way to repair would be to bore it out and have a dry sleeve fitted, you can then re-use your standard size OE pistons with a new set of rings...............................but being sensible you ask a friend how much he wants for his perfect and tweaked 2.1 engine, I'm sure Wills engine will be more than a match for your Van Halen one.
Either keep the auto or buy the whole lot, pedal box and all and put your effort into a conversion rather than an engine rebuild.
Plans are afoot.................lol
Possibly. Who knows.
Small update.... engine is back in, finally!.... but minus the transmission mount. It's currently resting on a block of wood on the subframe.
Can anyone confrim my hunch that there are two versions, one manual and one auto. I expect it's all in the bracket rather than the rubber mount.
I cannot confirm for sure but i am positive there are two gearbox mounting cradles, one for auto and one for manual, Paul ran into this with his recent conversion project as well i believe.
Yes russ.. there are two sorts one for auto one for manual..
The reason for the two is the clutch cable end rest is built into the mount as a single cast..
Thought as much. Thanks chaps for confirming that.
Whose bloody idea was it to do this conversion!!!
One for our headstones, Russruss92xmsed wrote:Whose bloody idea was it to do this conversion!!!
Tell me about Chris!
