I haven't seen an XM in Teesside for quite a few years, is yours on the road and what area are you in? I used to see a burgundy one around and about, is that one yours? Good to hear from you...maxferreira wrote: ↑Mon May 16, 2022 6:55 pmLovely looking car!
glad you're getting it restored
i notice, Teesside.....i'm also in Teesside
so, there's an another XM in Teesside, how wonderful!
XM V6 Sei finally going for restoration
dcz1643
Re: XM V6 Sei finally going for restoration
Derek
1990 Citroen XM V6 SEi
1997 Ford Explorer V6
2011 Jaguar XF Diesel Sport
1974 Triumph Spitfire 1300
2024 Explorer EV
2024 Explorer EV
dcz1643
Hi Guys...
My mate Pete has been in touch (he is the guy who has the XM in his workshop at the moment, down in Wisbech. He is a great mechanic but he normally works on vintage Triumphs, so he is asking for a little advice. He is working on getting the engine sorted and the original problem (when I took the XM off the road) was the starter motor. I will paste his message and some pictures, so if anyone can offer some support, that would be great...Cheers Derek
"Hi Derek, finally managed to get to the XM this afternoon.
I connected a fully charged battery and as soon as the battery was connected I could hear the starter solenoid thumping inside so it does sound like the starter is goosed.
It's not too difficult to remove but looks like this bracket needs to be removed but not sure how it unbolts? It seems to be attached to the housing that holds the sphere.
In the picture is the bracket that needs to come off so I can get to one of the bolts (I have a spanner sitting on top of the bracket."
Derek
2024 Explorer EV
2024 Explorer EV
Two bolts go through from the starter side and the third is accessed from the gearbox side. It fiddly but can be taken off with the hydraulics in place. But can be made much simpler taking them off. He will need to be mindful and take note on the flow divider and the return and pas feed are same size and can be swapped over which isn't good.
If you need starters I have pleanty Inc a. Couple of just about new ones here.
maxferreira
- Orga / RP numbers: RP6043
Mines a grey 2.1 td auto, only been here since Aprildcz1643 wrote: ↑Thu May 19, 2022 9:19 amI haven't seen an XM in Teesside for quite a few years, is yours on the road and what area are you in? I used to see a burgundy one around and about, is that one yours? Good to hear from you...maxferreira wrote: ↑Mon May 16, 2022 6:55 pmLovely looking car!
Currently sitting at a garage in Thornaby awaiting repairs to start on Monday
I'm in Middlesbrough, hoping to have mine on the road around this time next week, feel free to have a drive of her, she does need some work
I'm so pleased there's another local one, should meet up and get both the Teesside XMs together, I can't see there being any others
dcz1643
Thank you so much for your quick and comprehensive reply. I will send this to Pete and get back to you when I know what he needs to replace/sort the starter motor...Cheers Derekcitroenxm wrote: ↑Thu May 19, 2022 9:31 amTwo bolts go through from the starter side and the third is accessed from the gearbox side. It fiddly but can be taken off with the hydraulics in place. But can be made much simpler taking them off. He will need to be mindful and take note on the flow divider and the return and pas feed are same size and can be swapped over which isn't good.
Derek
2024 Explorer EV
2024 Explorer EV
dcz1643
Hi, mine has been shipped down to a friends workshop in Wisbech to be sorted (I am in Eaglescliffe). I am handy with the spanners but I don't have a car lift, so it is much easier for Pete to do the work down there.maxferreira wrote: ↑Thu May 19, 2022 9:59 amMines a grey 2.1 td auto, only been here since Aprildcz1643 wrote: ↑Thu May 19, 2022 9:19 amI haven't seen an XM in Teesside for quite a few years, is yours on the road and what area are you in? I used to see a burgundy one around and about, is that one yours? Good to hear from you...maxferreira wrote: ↑Mon May 16, 2022 6:55 pmLovely looking car!
I also have a 1974 Triumph Spitfire, so that keeps me busy with the oily bits!
When it comes back up here, we could have a meet, that would turn a few heads!
Cheers...Derek
Derek
2024 Explorer EV
2024 Explorer EV
If you can get her on the road be early July there's the citroen car club national meet in abbots Ripton. Now she will get attention there being a new car to turn up
(8th 9th 10th of July)
maxferreira
That would be good for sure! Certainly not an every day sight seeing 2 togetherdcz1643 wrote: ↑Thu May 19, 2022 10:26 amHi, mine has been shipped down to a friends workshop in Wisbech to be sorted (I am in Eaglescliffe). I am handy with the spanners but I don't have a car lift, so it is much easier for Pete to do the work down there.maxferreira wrote: ↑Thu May 19, 2022 9:59 amMines a grey 2.1 td auto, only been here since Aprildcz1643 wrote: ↑Thu May 19, 2022 9:19 amI haven't seen an XM in Teesside for quite a few years, is yours on the road and what area are you in? I used to see a burgundy one around and about, is that one yours? Good to hear from you...maxferreira wrote: ↑Mon May 16, 2022 6:55 pmLovely looking car!
Cheers...Derek
dcz1643
Thanks for the Heads Up, that will be up to my mate Pete but it’s something to aim for
Derek
2024 Explorer EV
2024 Explorer EV
maxferreira
Mine should be on the road by the end of next week
would you like a drive of it? get familiar with an XM etc
