They are broken. I am happy to obtain these from you. If cars are left in the sun in Thailand they become brittle. Then mechanics handle them wrongly and this happened here. Yes I earlier got the wrong advice on dash and thank you all for correcting me
Also need seat belts and possibly switches for window winder
Introduction to Kevin
Kevin
Re: Introduction to Kevin
The seat belt is part of the tensioner.. I'm not sure if I have one of those. But can check.
I'll Check out what I have in the unit tomorrow and get back to you..
I know I have the front panel around the switches.. Infomafion displays. And heater..
I'm not positive on the speedo section around the speedo..
I have the under the dash passenger side section
What's wrong with the switches for the windows.?
Kevin
The video above showed switches - may be bodged on drivers side?
Yea it showed switches. But visually I can't see anything wrong with them. That's why I was asking what's wrong with them.
Kevin
Ok they are ok. I wondered why the two were different
These are some of the problem parts (not all)
The glove box inside, indicator and dash parts
Rear reflector faded
I have a glove box... I'm sure.
Il need to check on A in the diagram for you..
I have part. B and part C for other end under dash..
I have a glove. Box..(or should have.)
Rh display I don't think I've any left now sadly. The liquid crystal leaks on the display. It happens here in uk too.
Kevin
This is looking promising. Thank you. Looking forward to what you find. Lefthand display works but right hand does flash and is faded. Are the repair kits on ebay any good?
The repair. Kits are for Lh displays only. I'm not aware of rh displays repair. Kits.
I have recovered parts B and c.. Referring to the diagram above.
I have asked someone for part C.. Won't know till tomorrow.
I'm positive I have a glove. Box I'll find out. Wednesday when I goto the farm..
The carrier that holds the lcd. Displays inside the broken part B do you still have that in decent order..? I can't find one at the very moment.
