E-bay Hydroactive II Suspension Repair Kit
basingbob
XM newbie
Post by basingbob » Sat Dec 12, 2009 12:04 pm
Hi
E-Bay item number 200345138590 Hydroactive II repair kit,
Simple Question -Has Anbody bought one - Do they work, is it worth it ?????
[sorry havent worked out how to do that direct link thingy yet although i did see it somewhere][now put correct number in - sorry !!!]
Basingbob
Re: E-bay Hydroactive II Suspension Repair Kit
Post by Peter.N. » Sat Dec 12, 2009 2:28 pm
Hi Bob
The number doesn't work either but if its the diode kit, yes, it works if that's what the problem is, I have fitted diodes in several and they have restored normal function. I didn't use the kit though, I fitted the doiodes inside the ECU.
Jan-hendrik
Post by Jan-hendrik » Sun Dec 13, 2009 11:15 pm
It's worth it. It's called insurance.
minijet
Post by minijet » Mon Dec 14, 2009 12:30 am
Hi Bob,
How to paste a link.......
It's a bit difucult to explain in words, so here's a video......
http://www.youtube.com/watch?v=tccRVgb5pCI
This is the first one I found. If it's not very clear simply try searching (on You Tube or Google) 'How to paste a url'.
There are lots of instruction video's on the net.
Post by citroenxm » Mon Dec 14, 2009 3:14 pm
Hmmm,
sorry to be a confusing sod, but Ive found one fitted to a mates car, actually doesn't seem to be dooing its job, and the car is still constantly in soft mode one moment then suddenly back into hard..
Car has had hydraflush and LHM change, ALL spheres changed, and the e croft kit fitted too.. tried a same year ECU aswell...
Post by Dean » Mon Dec 14, 2009 6:48 pm
Have you had the ecu hooked up to a lexia? it could be an ecu fault other than the common diode/driver failure as found by stempy on FCF or it could be a sensor issue, the steering sensor is a favourite i believe along with the other 3, ive heard rumours that just clearing the fault codes makes a big difference but its not anything ive experienced so i cant say if it does or not.
Jan-hendrik
Post by Jan-hendrik » Tue Dec 15, 2009 10:25 am
A few thoughts:
Performing a fault analysis with the proper equipment may be a good idea.
Clearing stored faults won't cure an intermittent problem, I think.
Fitting the external diode set won't cure faulty wiring/connectors/mechanical problems.
Flushing does not always/rarely cure a neglected hydraulic system.
Stiffness regulators can become so dirty that even flushing won't fix them.
