I've gone and purchased the wrong gasket for my thermostat. It's part 1339.66 PSA original I think its for 2.1L diesels.
Let me know if you can make use of it otherwise it's going to go to waste.
Thermostat Gasket 1339.66
paulstringer
Citroen XM (S1) Prestige, 2.0i Turbo. Black. 1993.
Re: Thermostat Gasket 1339.66
In the event of unobtainable gaskets I run a bead of silicone sealant around one face and leave it overnight to cure, you then have a nice semi flexible seal.
paulstringer
i actually have some of the Granville’s stuff but Lucky enough to find the correct gasket on eBay for a few quid. Good to know there’s an alternative.
- sageman
I make a gasket out of a rubbery gasket material you can buy in sheets on eBay if they can’t be bought
1976 Reliant kitten
1998 Peugeot 306 GTI-6
1993 XM sei V6 RP 5876
Liquid gasket seal (I think it's a polyurethane adhesive) available. Soecified item for Toyota steel engine sump to alu block.
There is also Viton sheet material on Amazon, eg 300x300x1mm, which can be cut to size.
