Xm items I hold currently
As of 13 Oct 2019.. The following is some of my Xm parts holdings.. Its far from complete and will be completed further when I move to my new shed.
For now though if you fancy anything adk though it may take a while to find.. Lol..
XM Full Inventry.
Double Door Shed:
Ahead of door: Floor. 6 speed Hdi 2.2 Manual Box, Be3/5 Manual box
2x Xantia PAS Racks – One missing pinion to ram Pipes, other complete, but boots knackered.
2.1 Td XM Manual gearbox from J reg 2.1. 160k all good
Left to right of pile:
• 1x Set of Non Wood Leather door cards, rear reversing lamp panel, S1 with badge. A centre
console unit frame, unbroken at all!!
E Systems Box: PAS Flow divider and regulator and joining pipes. Leaky on regulator and PAS
divider
• 2 sets of Leather door cards with wood inserts, One set missing drivers card
• Behr Water Radiator. 2.1 TD TCT type in good order, RH side of pile
• Exhaust back box, good order, RH Side
• PAS Rack, no pinion valve no track rods, Feed pipes good, pinion to RAM pipes present, RAM
present.. RH side
• Regulator unit and PAS Flow Pipe .. RH Side
XM Items. BOX A
• Clutch Cable, gearbox to quadrant
• 1x headlight rear cap cover
• S1 Engine fusebox, battery leads siezed on end
• S2 steering wheel radio control leads to phillips radio
• Moss Green type fuel filler flap. Good spring
• TD air filter to join air intake pipe
• Intercooler RH Pipe
• 1x Rear seat hinge leg cover in grey
• Pair of rear inner screen roof brackets, No pins and only one bolt and roof nut on each
• 2x PRV Dizzy cover upper half
• Manual car brake pedal switch
• Mk.1 interior fuse box
• Boot trim inside side Vent
• Grey front heater air outlet trim, passenger side
• PAS Pipes feed to pinion, good order no seals
• Front Bumper lower removable trim. Smaller type
XM Items. BOX B
3x PRV upper dizzy covers
• 2x PRV dizzys, knackerd contacts but lower covers present
• 1x ok rotor arm PRV
• Ignition AMP PRV
• 3x idle control valves
XM Items. BOX B (Continued)
• Some Red PRV Ignition leads
• Crank Sensor
• 2x Long gear change rods. Possibly 2.1 TD
XM Items. BOX C
• Large diamiter Pully Hydraulic Pump
• D6RA Starter Motor
• Petrol injecton in tank fuel pump
• Blower motor air intake cover from in scuttle
• Parking Brake equaliser unit, slightly stiff with head shield
• Gearbox mount with clutch cable mount port
XM Items BOX D
• 2x boot locking solinoid motors – working condition not known
• Wiper stalk non trip with varible timer
• S2 Heater panel, Air Con type
• Single spoke steering wheel centre boss with radio controls, red badge slight badge damage
• Twin Spoke wheel centre boss with black badge and radio controls. ALL Good
• 2x heater servo motors
• Front N/s door rubber seal on car
• Boot lock, key type.
• Rear ash tray frame
• Grey Cloth door bin not broke
• 2x Oval grommets
• 2x rear ash trays, not smoked in either
• Leather door bin lid only not broke
• S1 heater panel A/c
• 3x roatry heater front panels with climate control
• 2x auto selector lever surrounds, non wood
• 1x grey roof console
• 6x black Jeesus christ handles
• 1x short blind that sits behind rear view mirror in grey
• 1 set of 4 interior door handle surround trims off door cards in black
• 2x central warning light units
• 1x indicator stalk, no main lights on switch
• 2x roatry lights on switch
• Wiper Stalk, no varible timer
• 2x LH Displays
• 1x RH Display trip computer type
XM Items BOX E
• 2x ECU box top covers
• Clutch cable quadrant housing
• Mk.1 fuse box. Good Order
• 2x Height corrector. Nice and free in good order. Look leak free
• Altinator/HP Pump tensioner bracket
• Horn
• PRV Top hose support bracket
• Battery hold down clamp, no long bolts
• Engine Oil Filler Cap. PRV
• Top engine mount, circular one sits on chassis leg
• Pair mud flaps, citroen on them
• PRV Dizzy upper cover
• H5 Hydractive ECU
• Passenger Front and rear door lock mechanisems (Inside door)
• Rear Drivers door lock (inside door)
• parking brake release lever
• Bumper under trim, small piece in white
• 2x Rear subframe mounts. 1 good order, 1 needs a clean up
• 2.1 TD Water outlet manifold. Head to Rad with Wax Stat and couple small pipes.
XM Items BOX G
• 2x Plastic Black Frames, for something... :-/
• 2x Black odments tray front section of centre console
• Switch frame/mirror switch frame front centre console
• S2 rear centre console 12v socket and ash tray holder electric seat heater switch houses
• Boot trim Vent Unit
• Pair of dash tweeter covers
• 3x door speaker grill covers
• 2x keypad immbolizer under tray frames
• Black foot vent for heater outlet
• Rubber trim attaches to stering upper shroud
• Rear reading lamp and courtesy lamp, black trim
• 2x Door puddle lamps
• 7x Heater roatry control knobs Black with spring plates
• 2x Vent grills for B pillar trim
• 1x Roof console, black good sunroof switch, no lens
• 1x roof console, grey, worn SR switch with lens.
• Front seats runner rear leg mounts plastic trim covers in black
• Passenger side boot lid trim grill that covers access to lamps
• 4x black passenger side only trim surrounds for door open handle
• Lower radio din cubby tray – black
• Black radio/ash tray flap cover unit with release switchs
XM Items BOX G (Continued)
• Pair black sunvisors with mirrors but no illumination
• Door card window switch frame unit
XM Items BOX F
• passenger Door mirror, small glass plastic surround
• Rear drivers door upper cill plastic trim
XM Shed full inventry by Box Letter/Number 2015
BOX T
• 4x Petrol injection fuel pump/level senders. ALL OK
• 1x DERV S2 fuel level sender - Clip on pipe type
• V6 Fuel pressure
BOX V
Air con pipe work for 2.1td
HARNESS BOX 1 .. On centre table at back on top of window winders box
• S2 centre console harness I think
• 2.1 SED 1990 Engine harness loom
• 2,1 TD Engine loom with conduits for 1994 L reg. Base model auto
• L reg harness from fuse box in car to behind passenger headlight. Auto
• 2x S1 Front door loom
• S2 Passenger front door loom with dipping mirror control and black box
• Wiper motor to main loom extension section for RHD
• S2 Air Con heater loom. Control panel section to heater box
• Base model centre console loom from front to both rear B pillars. No power rear windows, with
electric mirrors.
• S1 Roof console front..
HARNESS BOX 2 ... On top of harness box 1 centre table at back
2x 2.5td engine looms, im sure!
RED Hard Box container SPEEDO BOX
2x petrol auto clocks S1. 1 with 194k one with 125k both complete
1x petrol manual clocks S1 complete with 99k
BOX W - On centre table in the centre..
• 1x Drivers door bin all good with cloth trim lid
• 6x interior door open lever surround trim
• 2x Roof console in grey with roof switch.. all good no bulbs only holders
• 2x " " " " " " " . switch worn.. inc cabin temp sensor.. no bulbs 2x holders
• 2x Autobox gear selector display units.
BOX W Continued
• roof console lens
• 2x Interior fuse box
• Jeesus christ handle surround trim grey
• 6x door puddle lamps
• under bonnet light lens cover
• 2x glove box lamps
• 2x footwell lamps
• 2x Height lever selector trim
• 2x sunblind retainter posts in grey
• S2 steering wheel shround. bare case
• 2x bonnet catchs
• 1x door open stay bar
• Jeesus christ handle in black
• Trip computer display, knackered lcd
• Rear roof side cortesy lamp
• Auto selector lever lock release button
• Set of Front wish bone arm bush's 4x fronts.. 2x rears..
• 2x outside door handles.. not broke
• 2x circular grommets
• Centre console block trim for Mirror/cubby pot area..
• Front ash tray. started pitting on the chrome
• lower DIN box under radio
• Front seat Left side plastic trim with seat switch
THE PIPE BOX - Hydraulic and cooling pipe work.
• Flow divider with V6 24v LHM Pump feed pipe to divider and Divider to Regulator pipe and
Rubber return hoses.
• Expansion bottle to thermostat housing small bore pipe, 2.1td
• 2.1 TD Top hose, with an added wear protector..
• Another regulator to flow divider pipe..
• Pair of rear Brake cailper feed pipes
• N /s rear strut feed pipe WITHOUT the 3.5mm pipe return to front..
• N/s rear strut pipe with 3.5mm return pipe junction. Pipe has hole in the metal
• Fuel pipes. Pair in a shape of a J...
• 2.1 td thermostat housing outlet to heater matrix pip. rubber moulded onto metal at lower end
• 1 pair Heater Matrix feed pipes, Alloy
• Coolant bottle tank pipe to Rad outlet. Small bore, small length
BACK OF SHED On rear most table..
• Cloth Seats, missing drivers seat.. (its in L reg 2,1 td auto)
• Air bag steering wheel,
• 2.1Td air con pipes from evaporator to drier and one to compressor and one to air con rad
• 5 or 6 wiper arms.
• An LHM tank with level sensor and filters
• Nearside front and rear door moulds in grey
• Height control lever, broken plastic top bit
S1 WINODW WINDERS Box.... Back of centre table
1x OSF
5x NSF
3x OSR .. 2 with broken clips
VARIOUS STUFF - Box 2 .. Back of centre table on top of window winders
• 1x rear caliper dust shield - with abs hole, good cond.
• Battery clamp, no bolts
• 2.1 SOLID crank pully, dual belt type, no keyway slot
• Gearbox mount dust cover
• Battery positive clamp and cables
• Idle control valve
• reversing lamp holder from out of boot centre panel
• 2x Fuel cap
• 2x Bonnet Lock one with sensor
• 2.1td HP Pump belt idle pully
• 4x horn untested
• 2x 2.1 td turbo boost sensor
• Parking brake equaliser unit
• throttle pedal
• Battery EARTH lead with clamp
• Coolant cap
• rear wiper motor
• spare wheel carrier hook
• OS rear boot lamp
• N/s Manderin rear lamp centre coloured trim
• ECU Box top cover
BOX A1 - At back of centre table
• Dual zone heater front panel
• base model centre console trim with mirror control switch
• Black Jeesus christ handle surround trim
• S1 keypad and housing no flap
• Black jeesus christ handle
• Grey front heater foot well outlet trims
BOX A1 .. Continued
• S1 radio controls for steering wheel, just buttons
• Electric seat backrest recline motor
• Pair of rear inner screen hinges that bolt to roof
• under bonnet lamp and holder
• oil level sensor
• 2x number plate lamp units
• Bonnet lock
• Door open stay bar..
• S2 headlight washer top, broke on corner!
• 2x Black front seat side trim, goes on side of seat between seat and inner door cill area
• headlight rear cap
• S2 steering wheel shroud with a cruise control stalk
• Sunroof motor
V6 12V AND 24V BOX - Centre table, in middle
• Starter heat shield
• 12v ECU with code
• fuel injectors manifolds with 4 injectors
• 2x ACAV 24v units with electrovalves
• some 12v HT leads in red
• Altinator belt
• Idle control valve with pipe to air cleaner
• Inlet throttle body rubber seal where air pipe goes on
• Thermostat houseing outlet to rad bottom outlet HOSE with pipe to oil cooler on autobox
• 12v Heater matrix pipes to engine
BOX A2 -
• Grey roof console, bare, worn switch
• 2x grey jeesus christ handles
• 4x grey covers for rear seat runners, covers the 16mm bolt
• 2x reading/rear courtest lamps
• Roatry heater dial black
• small sunblind from behind rear view mirror in grey
• Parking brake release lever lower cover, black
• B pillar rear passenger vent direction flow
• Black seat side trim, sits between seat and inner cill
• Blower motor air intake grill
Anything v6 24v prv specific is being kept unless there's more then 2.. But there is more to add..
I will need to slim down due to shed size change.
XM Full Inventry.
Double Door Shed:
divider
present.. RH side
XM Items. BOX A
XM Items. BOX B
• Ignition AMP PRV
• Crank Sensor
XM Items. BOX C
XM Items BOX D
• 2x Oval grommets
• 2x LH Displays
XM Items BOX E
• Horn
• H5 Hydractive ECU
XM Items BOX G
XM Items BOX F
BOX T
• V6 Fuel pressure
BOX V
electric mirrors.
BOX W Continued
• roof console lens
• 2x footwell lamps
• 2x bonnet catchs
1x OSF
5x NSF
• 2x Fuel cap
• 4x horn untested
• throttle pedal
• Coolant cap
• rear wiper motor
• OS rear boot lamp
• ECU Box top cover
BOX A1 .. Continued
• oil level sensor
• Bonnet lock
• Sunroof motor
• 12v ECU with code
• Altinator belt
BOX A2 -
Lwdajo
Re: Xm items I hold currently
Wow, I will need to reread that lot a couple more times!
I would be interested in (if compatible with 2.1TD Mk2 1994/1998):
Auto gearbox gear selector display unit (my 1994 intermittant gear display fault. Are there different variants of the PCB?)
Air con pipework (my 1998 has a leak, not yet investigated cause).
Rotary heater front panel with manual rotary switches (my 1994 has a rotary switch which does not travel fully across the range).
Thanks,
Lee
Thanks,
Lee
Lwdajo
And for spares, I would be interested in Mk2 2.1TD coolant hoses, if you want to clear more space.
LH and RH displays also useful, as Will needed my last spare RH display.
Thanks,
Lee
Thanks,
Lee
Hi Lee
S1 lh displays are not compatable with S2 cars sadly.
I've got 2x 2.1td cars to consider of my own. But I'm sure there's possibly more. I broke two x 2.1 td cars last year.. And there's other bits no doubt..
I've a few selector displays. They are a seperate pcb in the binnacle that sits behind the fuel and temp guage display dail. I can sort one of those..
Air con pipes I've used up r134a pipes I had on a 2.1td auto I've just done a box swap on. I may have another set but not certain till I start sorting. The sed I broke last year was an R12 system.
I've got an S2 heater control box.. They are very different to S1 units which do break very easily..
I assume for early S2 derv it's NOT got a trip computer.. So it will be basic clock. I'd need to get displays together and see what I have.
Yur coolant hoses. Are they standard clamp connections or bayonet connecting hoses?
Lwdajo
Hello,
Just picked up the 1998 car for the first time today since purchase (long garage stay) and had a quick look.
Coolant Hoses:
On the 1998 car the coolant hose to the thermostat has bayonet on the non-thermostat end. Hard to see the others at a glance. Will look again tomorrow. On the 1994 car, it's garaged away from home, so will look early next week (doing a few jobs on it next week).
Aircon
The aircon is r134a in the 1998 car (the 1994 car has manual rotaty knobs and is climate control only as a VSX).
Trip Computer
The 1998 car may have trip computer - I'll play with it more tomorrow. I thought the 1994 car had as well, but could be wrong, double check next week.
Thanks,
Lee
Coolant Hoses:
Aircon
Trip Computer
Thanks,
Lee
1994 derv cars won't (unless a 2.5td)
You know if you have trip there's a button on the end of the wiper stalk useually white..
..or grey/black, if the paint hasn't worn off!
Lwdajo
Yep, you were right, my 1994 does not have trip computer but my 1998 does (and the stalk button is white-ish).
I should never have doubted you!
Anothersmith
- Orga / RP numbers: 1993 sei Turbo
Hi mate,
I had a search through and I am interested in the PAS Rack, no pinion valve no track rods, Feed pipes good, pinion to RAM pipes present, RAM
present.. RH side if you could give me a price delivered to South Wales (Newport).
I am also looking for a glovebox handle, armrest (top only if possible as my hinges have broken), and the door and hinges or surround to the immobiliser code keypad. All for a 1993 S1 sei turbo model. If you come accross those on your shed clearout I would be grateful for a price.
Cheers
Cheers
Loads of glove box tops no problem.. I will split
I may have a spare keypad lid and frame too.
Pas rack no problem.
I shall pm you further..
Thanks.
Thanks.
