Window glass black plastic clips.
rosspa
Post by rosspa » Tue Sep 24, 2019 1:00 pm
Hi, Has anybody have a couple of door glass to runner retaining clips or know where I can get some? When changing rear doors shells, I must have put them somewhere 'safe' and now cannot find them.
Thanks.
Re: Window glass black plastic clips.
Post by White Exec » Tue Sep 24, 2019 2:34 pm
Are you after the complete plastic block that runs up and down the metal track, or just the C-clip (that is usually attached by a thin flexible strap) ?
rosspa
Post by rosspa » Wed Sep 25, 2019 2:48 pm
Hi Chis, it is not that part, but the complete black plastic block ( about 2x1x1cm) ot the rear edge of the glass which keeps the glass parallel in the runners in door frame.
Post by White Exec » Thu Sep 26, 2019 9:06 am
Can you identify the parts from here...
Click diags to enlarge
rosspa
Post by rosspa » Thu Sep 26, 2019 7:44 pm
Hi Chris , Would be item 7 on both diagrams. Next item on the list in both item number lists (can't see). Not sure if front and rear are the same, or left and right. Suspect that they are all the same. I am missing lh and rh rear.
Post by xmexclusive » Thu Sep 26, 2019 8:21 pm
They are all the same, the drawing makes them look more complex than they actually are.
I will have a few spares but no idea where to look for them.
rosspa
Post by rosspa » Fri Sep 27, 2019 11:22 am
I would be very greatful if I could buy a couple of the clips. I've hunted high and low but cannot find mine. I do have a pair of bare emerald green rear doors in fair condition for free to take away. Some corrosion in vicinity of lower window to door seal, otherwise solid. Shame to chuck them.
rosspa
Post by rosspa » Fri Oct 04, 2019 12:10 pm
Have now procured window clips thanks to xmexclusive. Now after left and right electric window lifter assemblies.
Abime75
XM newbie
Post by Abime75 » Thu Feb 02, 2023 1:38 pm
Thanks :D :D
