Xm 2.1 s2 parts for sale.
messerschmitt owner
Citroen Xm series 2
Headlamp washers complete. Off side perfect and near side broken cover. £25
Pair of fog lamps good working order. £30
Pair of headlamps good working order £30
Front struts and strut tops - complete with hubs. Rechargeable spheres. Pair. £65. collect only
Working Stereo with code and owners manual £15
Front wings in blue £10 the pair. Ok condition with surface rust on bottom. Collect only.
Numerous other small parts to follow including indicators. Message me postage at cost via Royal Mail or myhermes depending on weight.
On collect only parts I do travel a lot with work. Near London and Surrey/Sussex this month and Norwich, Bristol and Scotland in October.
messerschmitt owner
Re: Xm 2.1 s2 parts for sale.
Excellent condition tow at for s2 estate £30. Collect only.
messerschmitt owner
Working s2 central locking ecu and working coded key remote. £40
- raynoon
- Orga / RP numbers: 6043
Front towing eye cover, passenger side?
- raynoon
Can I bagsy the radio for a friend of mine please
Strut tops too please
messerschmitt owner
I'll check. I may be able to do the towing cover.
- raynoon
A bit cheeky but I wonder if Russ could collect these and bring to Chevrons on Sunday?
The key fob and the grey ECU are not a working pair.
The RF receiver is a black box with a single white plug found on top the chassis frame when the glove box is removed.
The grey ECU is the door latch controller.
messerschmitt owner
ok will pull that out when I chop the dash out tomorrow and then it will be a matched working pair. Thanks!xmexclusive wrote:The key fob and the grey ECU are not a working pair.
Last edited by messerschmitt owner on Fri Sep 09, 2016 6:38 pm, edited 1 time in total.
messerschmitt owner
If Russ can come tomorrow that would be fineraynoon wrote:A bit cheeky but I wonder if Russ could collect these and bring to Chevrons on Sunday?
[/url]
