R/H driveshaft, new, £20
jamescarruthers
Post by jamescarruthers » Wed Nov 25, 2015 8:08 pm
I got this driveshaft for £20, however, although it seems the right length it is much thinner than I was expecting. I have a 2.1 TD manual; I suspect that this is for a 2.0 petrol. ‎
I was assured that it was the right one for my car (send model, chassis number, etc.) so I can send it back, but I thought I'd offer it on here as it was such a good price.
This is the long, R/H driveshaft‎.
If anyone else wants it, they can collect from Cambridge or Stansted for £20 or I can post it at whatever that costs on top. ‎
1987 Volvo 480 ES
Previous XMs:
H656 BKJ XM 2.1 SED
Re: R/H driveshaft, new, £20
Post by citroenxm » Wed Nov 25, 2015 8:55 pm
Early TD shafts WERE thin but solid shafts, making the same or simmilar strength to later THICK Hollow shafts...
Keep it james, it IS correct for the year!
jamescarruthers
Post by jamescarruthers » Wed Nov 25, 2015 9:03 pm
The car has thick shafts on now though. Will that be alright so you think-- L/H thick, R/H thin?
1987 Volvo 480 ES
Previous XMs:
H656 BKJ XM 2.1 SED
Post by citroenxm » Wed Nov 25, 2015 9:24 pm
Ahh not sure about thickness differences across the front.. thats a new one on me.
jamescarruthers
Post by jamescarruthers » Wed Nov 25, 2015 9:36 pm
I only needed to replace the L/H, I just thought for £20, I might as well do the R/H too. So, I can live without this installed.
I'll see if it fits anyway. I think the mechanic said something about it not having enough teeth either, or the splined end was thinner too. I may have imagined that part of the conversation though.
1987 Volvo 480 ES
Previous XMs:
H656 BKJ XM 2.1 SED
Post by Dean » Wed Nov 25, 2015 9:36 pm
I've done it and its fine, the tubular shafts are lighter than the thin solid ones so it would work better with the short one solid and the long one tubular but there won't be an issue, if your not happy and the splines are correct for an auto box you have a buyer waiting here anyway ;)
jamescarruthers
Post by jamescarruthers » Mon Dec 07, 2015 10:24 pm
Dean, the splines are smaler than my manual gearbox. Does that indicate that it is for the auto box car or is there more information that you need to check that?
Anyway, it is definately for sale due to being incompatible with my 'box.
Still boxed up so I can post pretty quickly.
1987 Volvo 480 ES
Previous XMs:
H656 BKJ XM 2.1 SED
Post by Dean » Mon Dec 07, 2015 10:52 pm
Auto boxes have bigger splined shafts, more splines but the outer CV joints are the same across the board, let me check my stock but I think I will have it off you anyway, will PM you tomorrow to confirm.
Thanks
Post by MTXM » Mon Dec 07, 2015 11:00 pm
On the PRV V6 the manual and auto shafts are interchangeable and I fitted some 2.0i turbo shafts on one of my 12v! Regards, Matthew T.
Post by xmexclusive » Mon Dec 07, 2015 11:35 pm
Citroen Workshop Manual Drive shaft information sheets.
