Wanted. Oil dipstick.
Bertie-Bassett
Has anyone got oil dipstick. Mines perished. Will ones available online fit?
citroen xm 1994.
- ragger
Re: Wanted. Oil dipstick.
Still available from the stealers, I believe. Had to get one a while back for the Diesel and shortly after that, one for a ZX. Bought one at the dealers and one on line but can't remember which way round!
An easy repair for the disintegrated plastic...
Might help you out, depending on the size of your dipstick tube.
viewtopic.php?f=5&t=6763&p=77413&hilit= ... air#p77390
Your stick dimensions will be different.
cxprestigeauto
Bet yours is more useful than mine:
normanlindley
Huddersfield
When mine went at the end went up to citroen spares and bought a new one for about £12 i think
norman
norman
Huddersfield Has no sunroof
Yep they are pretty cheap and readily available.
cxprestigeauto
There are plenty on sale but how do you know if it is the right length?
Mine is a very early 2.0 petrol. All the ones on Ebay seem to be later cars or for V6 or diesel.
Confused.
Confused.
They are extremely difficult to identify reliably from the adverts, which is partly the reason I repaired.
cxprestigeauto
As you can see from the photo I am not convinced this one is original!!! In fact I am pretty sure it is not original and therefore not much use other than to stop oil blowing out of the tube!!!!!!!
Any suggestions/advice welcome.
Yes.cxprestigeauto wrote:Any suggestions/advice welcome.
1. Get someone to measure the correct distance from High mark to Tube Top for your 2.0
2. Do a repair job (with your own steel/brass strip, or gash dipstick) as per my post above
Easy-peasy.
