Wanted.keypad cover ??
Bertie-Bassett
Hi has anyone got a spare plastic key pad cover ?? Cheers.
citroen xm 1994.
Re: Wanted.keypad cover ??
Is yours broken (hinges?) or missing?
Bertie-Bassett
No. Just never had one on it. Keys get dusty. And sometimes pop spills on em.
citroen xm 1994.
Bertie-Bassett
Non going spare then I take it?. Cheers.
citroen xm 1994.
ekjdm14
- Orga / RP numbers: 6470
Rare to find in decent condition as the clip usually breaks off that holds them shut, probably why yours was removed. I'm sure you'll find one, just a matter of time. Or deactivate the keypad and replace it with a cubby hole seems to be a common "fix" when one can't be found.
There must be some around scappie or otherwise.
If catch breaks, it's always possible to abandon the catch, remove hinge springs, and simply rely on gravity to keep it closed.
If hinge breaks, simply replace both hinges with a 2.5mm metal rod, running the width of the aperture, and a few mm into the side cheeks.
