Bendix calliper required
For reasons I don't understand my o/s calliper has a fair bit of play in the slide bushing, very clean low miles item with good seals and clean white grease in the bush still, not one mark on the shaft either, does anyone have a good calliper they would like to part with? Need it fairly soon for mot time as I don't want to have to swap later.
Thanks
Thanks
Re: Bendix calliper required
Which type of Parking Brake Lever Dean?? Straight early type, or Curved type???
Curved type Paul
Ok.. are ALL the curved type the same?
Its a good point, xm didn't get bigger Bosch brakes did they?
They certainly didnt get the xantia v6/hdi 110 calipers.. the only ones to be different will be the 2.5 td and v6 24v auto models..
Im sure i can spare you one dean.. do you need the carrier or litterally just the caliper?
From investigation all the wear seems to be on the bushes so I only really need the calliper Paul
Ok dean... how soon is soon though??
Ooh, you know. Yesterday?
Did you sort this dean??
