Wanted - couple of little bits series 1.5 xm
Post by Vince » Wed Jul 23, 2014 9:13 pm
Hi guys,
Im looking for a replacement tweeter (speaker) on my xm. I don't need the grill etc, just the small round speaker that sits beneath it ;)
I also need a front wheel arch rubber grommet from the passenger side. Its the one on the front edge of the wheel arch liner....like a rectangle with round edges :)
Can anybody help?
Thanks
Re: Wanted - couple of little bits series 1.5 xm
Post by citroenxm » Wed Jul 23, 2014 10:25 pm
Tweeter galore here vince. Im suprised to see you even asking!!
Prehaps a pic of the said grommet??
Post by Vince » Wed Jul 23, 2014 10:48 pm
Hi Paul I was hoping you'd pop up : ) Thought youd have a load :lol: Mine broke off at the connector on the speaker..i wondered why it kept stopping working.
Ill post the grommet picture up yes, trust me you'll have one im sure ;) I think they were standard on all xm's
Hope you're well ;)
Post by russ92xmsed » Wed Jul 23, 2014 11:12 pm
Vince, the grommets can be found in the boots of any pug 106 or saxo. I found two in a local scrapyard a few years ago. Best thing is, they will be in great condition.
Post by xmexclusive » Thu Jul 24, 2014 8:53 am
Hi Russ
There is a pair behind the rear bumper of an XM as well.
Post by russ92xmsed » Thu Jul 24, 2014 12:10 pm
Is there. I did not know that. Just knew of the front ones.
Post by Vince » Thu Jul 24, 2014 10:01 pm
Are there? very interesting.....does anyone have an OE number? I could buy two brand new ones then,,,they wont be dear :)
Post by XMX » Fri Jul 25, 2014 3:05 pm
Vince wrote:Are there? very interesting.....does anyone have an OE number? I could buy two brand new ones then,,,they wont be dear :)
Hi Vince ! Did you not read my comment/post in THIS thread :?
XMX wrote:
Vince wrote:Hi, what condition are the side door mouldings in...chrome trim wise? They are interchangeable with MK1's arent they?
Also on the front edge of the inner wheel arch liners there is a medium sized rubber oval grommet which when removed exposes the bumper bracket etc...i could with one of those too :)
Hi Vince,
I've just taken a look on the poly-bag that they come in 5's, (I have four new ones still) and the part no's is #6988.52
:idea: if you have a breakers yard near you, go on a raiding party for some !
See THIS thread for more info ;)
Just called the Main Stealer's, £1.43 + VAT each !
:lol:
djg
Orga / RP numbers: 7903
Post by djg » Fri Jul 25, 2014 3:20 pm
For something as cheap and easily available as this there is no need but for everything else similar, we have a shop here that stores every conceivable trim clip, cable and harness fastener, trim screw, captive nut and grommet out there in the wild. You just go there with a sample and they'll find one or a dozen in one of their thousand little boxes. They don't really care what make and model it's for... You'll probably have something similar in the UK, won't you?
Bye,
Gábor
Post by Vince » Fri Aug 08, 2014 10:37 pm
Hi Vince,
:lol:
Fantastic, thanks Matthew
