breaking for parts, 94 diesel estate 2088cc
southerner
All sorts of parts are up apart from the engine as that will be fitted to my other XM estate, there is a very good Auto-matic gear box, turbo charger ect ect, let me know what parts and name a price, not sure about the postage side or colletion some thing we can work out.
Breaking the car up will start at the end of this mth when tax and mot runs out.
normantilbury
Re: breaking for parts, 94 diesel estate 2088cc
Hi i looking for the Headlight/indicator switch on the stalk mine has started to set the relay off ticking away the contacts must have worn away.
Regards,
Norman
Regards,
Norman
southerner
Ok norman I put that to one side for you, MOT runs out on the 28th so I will be breaking the car down that week.
Pete
Pete
messerschmitt owner
That may explain the ticking on my rnm. I've a spare switch though.normantilbury wrote:Hi i looking for the Headlight/indicator switch on the stalk mine has started to set the relay off ticking away the contacts must have worn away.
Regards,
Norman
Thanks.
normantilbury
Thanks Pete,
Let me know what you want for it and i'll sort something out,
Just had the wheel bolts payment returned by paypal shall have to see what has happened there,
Regards,
Norman.
Regards,
Norman.
southerner
Thats good you have pay-pal make life easier, Offer what its worth to you any offer will do so long it inclues packaging and posting.
normantilbury
Hi Pete,
Is the internal fan hidden in the interior light assembly available? since i cleaned mine it gives me a fault on the lexia so i would like to try a replacment.
cheers,
Norman
cheers,
Norman
southerner
yes it available, will be starting to break the car up this weekend
southerner
the only part that will not be available is the engine, as that will be fitted into my 92 xm. but all the rest is up for sale.
normantilbury
Hi Pete,
Good then add it to the other part and let me know how much i owe you,
Regards,
Norman
Regards,
Norman
[/url]
