Where on earth would I be able to buy a new automatic gearbox temperature switch for my 1995 XM2 2.1TD.
Part # 1264 29
I foolishly cracked the switch casing while taking the engine out of the car.
Not hard to do mind you, as it is situated on the outer near side of the transmission.
Next time I'll be removing the switch first.
Wanted, ZF 4HP18 autobox temp switch
milcor
Re: Wanted, ZF 4HP18 autobox temp switch
I should have one of these. I will have a look to be sure though.
