XM Spares available
From XM Series 1, 2l petrol manual, Marelli Injection, 1990, Sei, golden beige
Car history, good condition: This car looked like new (especially inside) was low mileage, terminal engine fault
Body, interior:
Windows: all side windows, not small triangle windows
Rear, internal hatch separator window
Glove box
Spoiler (has a paintwork scratch, the one with the gap on two stand offs)
Seatbelts
Rear parcelshelf, black
Gas struts for boot and bonnet
Rear wiper arm, foldable, no rust (for spoiler cars)
Ceiling light panel, ashtrays (clean)
Roof bars (no name)
Various nuts and bolts
Electrical items: tons of switches, warning light panel, relays, rear windscreen wiper motor
Light stalk, wiper stalk, Horns,
Lockset: Boot lock, two front locks, ignition lock, two or three keys
Window motors with mechanics, all were good, not sticky
Horn, fuel pump assy
steering wheel rotary joint, ceiling fan motor
All central locking motors, good
Wing Mirrors, right one heated
Electronics:
ECUs: Injection Marelli G5.M0/0A02, ABS,
Hydractive1 Valeo H2 S2001 73807802,
ABS Bendix: B550976D
Ignition module BOSCH
Good dot matrix display, climate control panel, Plip (sold), temperature clock module, dashboard (crack in acrylics but that could be replaced with other window)
Lights: All Tail lights, brake cluster, fog light / indicator clusters, Front headlights assys, Sidelight assys (one broken), one off indicator unit R (the one without foglight, VALEO).
Engine items: hydraulic pump (reconditioned by Pleiades with not more than 1 year use since)
clean LHM reservoir, inlet manifold,
Most Marelli injection system items (sensors, injectors, fuel pressure regulator)
radiator,
Starter Motor
New, untouched Clutch Kit (as per Eurocarspares XM 2.0l and turbo) Transmech Germany # 641545061
Airconditioning: compressor (SANDEN SD-709) and condenser, large belt roller wheel
2 tyres Pirelli P6000 195/60 R15, almost new
Contact Michael 01494 449538 evenings or commercial.passler@talktalk.net
S1 1990, Various spares available:
- XM newbie
- andmcit
Re: S1 1990, Various spares available:
I could certainly give the clutch a new home where it's imminently needed! What sort of £? pm?
Also reserve the hydractive ECU for Mouseflakes Tim!!
Andrew
Andrew
- andmcit
Is the radio in gwo still available - Bantam wants one!!?
Andrew
Andrew
Thanks for thinking of me Andrew - however, I found a badly corroded connection on the electro-valve that I need to sort out before turning to the ECU. It may still turn out that I need one though.
Tim
1969 R16 GL - welding up
1978 R30 TS - resting up
1996 Saxo D - commuting up (?)
