PLASTIC BODY TRIM
juggernaut-j
PLASTIC BODY TRIM
Post by juggernaut-j » Tue Jul 03, 2012 9:07 pm
Hi
I always keep my 93 two litre si on the drive and this sunday was the first time and some tw@ has side swiped it (drunk i should imagine) the damage is superficial although i will have to have the offside resprayed the only broken bit is the plastic body trim just behind the passenger door does anyone on here have a good one they could sell to me or failing that a company that could supply
regards john :(
Re: PLASTIC BODY TRIM
Post by citroenxm » Wed Jul 04, 2012 2:11 pm
Have you any pictures for a clearer better idea??
Post by Dieselman » Wed Jul 04, 2012 6:22 pm
The strips went from medium grey to dark grey/black around this time, which do you need? I suspect you mean the small rubbing strip mounted on the rear wheelarch.
Post by MTXM » Wed Jul 04, 2012 7:10 pm
A 93 model would certainly be in the darker shade Will, assuming it is not body-coloured of course, in which case no problem! The estate wheel arch trim is the same. Regards, Matthew T.
juggernaut-j
Post by juggernaut-j » Thu Jul 05, 2012 8:31 am
Hi
here are the pics of the trim it is black and on the back wheel arch
regards john
Post by MTXM » Thu Jul 05, 2012 11:12 am
Nasty bit of damage there John that must have been very upsetting! I think I might have a spare piece of trim if nobody else can help. With regards, Matthew T.
juggernaut-j
Post by juggernaut-j » Thu Jul 05, 2012 4:52 pm
yeah mathew i was well peaved that car is (was) pristine its only done 29,000 mls and if you have the trim just let me know and how much inc.p&p
regards john
Post by MTXM » Thu Jul 05, 2012 10:38 pm
I shall be pleased to help John and have sent you a PM. With regards, Matthew T.
