WANTED
bobhowes
WANTED
HI UALL, HAS ANYONE GOT A ANTI SINK MODUAL I CAN BUY PLEASE, mine is leaking from the solenoid, have tried epoxy filler, so far without result, had unit out 4 times, its out now for last desperate attempt to repair, the leak at last attempt was down to a drip, was initially a stream, but i recon a replacement is the answer. here's hopeing. Bob.
Re: WANTED
Hi Bob
Are you sure its the anti sink valve you want, it sounds very much like the hydractive valve with the alloy electrovalve screwed into it that corrodes from your discription.
Re: WANTED
Hi Bob,
Is that a Front or Rear unit - actually, thinking about it, I think they are the same...
I may be wrong but I dont think S1.5 and S2 units are the same?? However, I may be able to help once someone can confirm which is which? I see your Estate is a LATE 1999 car...
Would these units be the same As Xantia VSX ones??? Anyone?
Re: WANTED
hydractive 2, hydractive 1 has a remote electrovalve so doesnt suffer this problem
Re: WANTED
And same as Xantia units???
Re: WANTED
dont know Paul, ive never seen an XM one
i would think they are wouldnt you?
Re: WANTED
They are the same.
bobhowes
Re: WANTED
Hi Dean, Citroenman,&all, im not sure what it does just assumed it was the anti sink, its situated just behind the gear box, it has two large pipes and two small a solenoid and a sphere. its here in front of me (jn the lounge) just tried some more epoxy, final attempt, but even if it stops the leak will still like to buy a replacment, dont think the epoxy would hold for long. I do miss the ride, im rattling and bouncing along in a boy racer 2 litre diesel,over 200,000 on clock, goes like a bat out of hell with my heavy boot 1 Hope the description of valve helps to determine what it is. Bob H.
Re: WANTED
Hi Bob
Do you just want the alloy bit or the whole cast block? is there any corrosion on the alloy thats making it leak? they should seat on an o ring where they screw in but if the alloy electrovalve is eaten away im sure someone will have one about somewhere.
bobhowes
Re: WANTED
Hi I forgot to mention that there is also a rubber return pipe that connects to the solinoid.
