Nice estate on Autotrader
9 photos
Technical Data
1998 S Reg CITROEN XM 2.0I SX 5DR ONE OWNER (trade)
Potton Motor Company
108,209 miles
Manual
Silver
Petrol
5 Doors, Manual, Estate, Petrol, 108,209 miles, Metallic Quartz Silver, MOT-08-2010, 1 Owner. Metallic paintwork, Cloth upholstery, Height adjustable drivers seat, Adjustable steering column/wheel, CD
Technical Data
108,209 miles
Manual
Silver
Petrol
Re: Nice estate on Autotrader
Its quite a tidy looking car.
I still can't make that work
Hi Peter
Links have to be to a silver 2.1 manual estate to work for you.
We would not like you to waste your time looking at any other XM's.
How is the ABS hunt going?
Hi Peter,Peter.N. wrote:I still can't make that work
It's very easy just hit the '' buton above the posting title box to get :-
a) [url] , then add in the = sign after the 'url' in the first box.
b) Then between the two '' boxes add a word such as i.e. 'E-BAY', 'AUTO-TRADER', 'THIS', or 'LINK' etc.
c) Then finally add the actual copied link from the source (Auto-trader, E-BAY, A PDF file, Exhaust Cataloge, Ref. to another post on this Forum, etc.) after the '=' sign to make the hyper-link work !
d) LINK
So Peter, if your still not sure ?
The best way is to actual see all that on the screen hit the 'Quote' button of this actual post and you can see that all the text etc. within both of the boxes in the d) bit (above) to see how the 'LINKY' work's.
Simple's
Every days a school day. Thanks Richard.
I suspect that when Peter finds a silver 2.1 TD manual estate for sale, he will be very quiet about it until its his!
Its a petrol one Johnxmexclusive wrote:Hi Peter
Funny you should ask about the ABS, I have just this minute come in from under the car, changed the relay, the ECU and checked all the sensors - still the light stays on - help!
I don't have an answer to the problem Peter, I'm just interested to know.....does the ABS still work?Peter.N. wrote:Its a petrol one Johnxmexclusive wrote:Hi Peter
John![]()
I have two cars showing the ABS warning light, but the ABS still works.......very mysterious
The short answer is I don't know, I never brake hard enough.
