Hi,
I'm after a Series 1 non EGR exhaust manifold, I would think it's needs to be from a 1992 or older engine.
Thanks.
Steve.
Series 1 Exhaust Manifold
- steelcityuk
XM 2.1 SED K Plate - RP5876
Scenic 1.5 dCi 100
Gone -
Scenic 1.9 dCi 130 FAP
Prius T Spirit
XM S2 TCT Exclusive Hatch LPG
XM S2 2.5 VSX Estate
XM S2 2.1 VSX Hatch
Xantia 110 HDi Exclusive
Pug 405 GTX TD
Scenic 1.5 dCi 100
Gone -
Prius T Spirit
XM S2 2.1 VSX Hatch
Pug 405 GTX TD
Re: Series 1 Exhaust Manifold
Phhooooorrrrr thats gonna be a hard find Steve!
I assume for your SED?
Ill keep ears open and let you know if I hear anything.
I think the early 406s used them - there are a lot more of those about.
Ignore this I read 'inlet'
You should be able to just remove the EGR valve from the manifold, and make up a little blanking plate to fit in its place.
Jonathan.
2004 Saab 9-5 Aero Estate
1999 Yamaha FZS 600 Fazer
1991 Kawasaki GT-550
1986 MZ ETZ 250
1986 MZ ETZ 250
That actually, Johnathan, worked well on a Xantia I did..
I swapped a Turbo from a 1997 EGR equpit car to a 1996 non, and made and bolted a blanking plate..
Caused no problems at all!
We also plugged the inlet manifold too... all worked fine!
- steelcityuk
I was intending originally to go along the blanking plate route until I found out earlier cars didn't have EGR but if they are rare then a plate it will be.
Thanks all.
Steve.
Thanks all.
Steve.
Scenic 1.5 dCi 100
Gone -
Prius T Spirit
XM S2 2.1 VSX Hatch
Pug 405 GTX TD
Scenic 1.5 dCi 100
Gone -
Prius T Spirit
XM S2 2.1 VSX Hatch
Pug 405 GTX TD
