steering wheel plate
hi
anyone know where i can obtain a blanking cover for a sinlge spoke steering wheel? i want to remove radio buttons i have been told that there was a single spoke wheel without radio controls? does anyone have one lying around unwanted
thanks
thanks
- andmcit
Re: steering wheel plate
That's right - I may have one somewhere. I believe the front panel is a separate removable piece though
if it isn't it was only fitted to the pikey spec models mind so the wheel won't be leather bound...
Will need to get back to you on this as I've got parts lying around all about the place so unfortunately
feedback may take some time...
Andrew
Andrew
thanks for that, much appreciated ill await the results of your hunting maybe even one with buttons removed that i can adjust to fill in the holes somehow.
Im sure D hallworth has got one liying around off a V6 from years ago...
thanks, how do i contact him?
- andmcit
Hang on! I'm sure Citroen didn't sell V6's without steering wheel controls?
DavidH's can't be original if it was off a V6 Paul!
Andrew
Andrew
Quite possibly Andrew, but thats what was about when that wheel was about...
Ex-em,
Contact David here:
Contact David H
Click the Email or PM david on the left.
Ex-em,
Contact David here:
Contact David H
andrew did you manage to find one? if not im still looking if anyone has one?
- andmcit
Sorry, no I've not seen one without switches - have a few of the switched ones from what I've found so far though.
These were only ever on the very base models - not something many folk would be bothered about keeping or
even saving parts from. I do have a car which has the base steering wheel but would prefer to keep it standard.
It even has the rigid plastic not upholstered centre console cubby...
Andrew
Andrew
Sounds delightful, is that one of the old 2.0 i s with no adjustable rear headrests?
