breaking for parts, 94 diesel estate 2088cc
Re: breaking for parts, 94 diesel estate 2088cc
Post by MTXM » Wed Jul 10, 2013 10:12 pm
I thought the early and late non-sunroof cars were the same Paul in that they have an identical light fitting at least! Perhaps I am wrong, but I believe this car has no sunroof, although Neil does now seem to have other plans. Regards, Matthew T.
messerschmitt owner
Post by messerschmitt owner » Thu Jul 11, 2013 5:31 pm
I thought ed had a hatch and this is an estate? I'd say the headlinings differ slightly between either variant
Are the door lock switches from the inside doors available. These are the bits atop the door cards.
Image[/url]
Eddie nuff
Post by Eddie nuff » Sun Jul 14, 2013 7:01 pm
messerschmitt owner wrote:I thought ed had a hatch and this is an estate? I'd say the headlinings differ slightly between either variant
The estate headlining differs from the hatch one only at the rear end where it is obviously longer and slightly wider.
Thanks for the help fellas but I now have what I need to make one to fit my car - it's just a matter of finding the time. :(
southerner
Post by southerner » Thu Jul 18, 2013 7:58 am
It never rains but pours, rebuilding the other XM, I getting a problem no Turo reading on dash and the ABS light staying on, (flickers a bit when first starting up). any you guys know what could be at fault.
Post by xmexclusive » Thu Jul 18, 2013 9:53 am
Hi pete
Will see if I can find a cleared ABS ECU and we can try that.
southerner
Post by southerner » Thu Jul 18, 2013 11:36 am
i tried the spare ecu but the problem is still there, i think it must have some thing in common with the turbo gage as thats not working all so, but engine sounds like it is
southerner
Post by southerner » Mon Jul 22, 2013 8:30 am
Ok I started to strip the inside of the car now, who was it that wanted the bolt on chass parts
Post by MTXM » Mon Jul 22, 2013 11:06 am
I collected my bits from Norman at the National CCC Rally on Saturday and many thanks again for you help. Regards, Matthew T.
southerner
Post by southerner » Mon Jul 22, 2013 1:44 pm
Your welcome, i will try and keep as much as i can safe in storage just incase some one might need parts
southerner
Post by southerner » Wed Jul 24, 2013 1:25 pm
Wow its gone quiet
