Hi Dean, Its the alloy bit thats leaking, corroded into a mush, tried to remove but couldent because of the corrosion, afraid to put too much torque at the time but if had a replacement would remove old one, one way or another, so in answer to your question, just the alloy bit would do fine. I think the sphere is ok! Bob H.Dean wrote:Hi Bob
Do you just want the alloy bit or the whole cast block? is there any corrosion on the alloy thats making it leak? they should seat on an o ring where they screw in but if the alloy electrovalve is eaten away im sure someone will have one about somewhere.
WANTED
bobhowes
Re: WANTED
Re: WANTED
I will have a look, i dont know if the ones i have are rusty or mangled or not but i will check tonight.
bobhowes
Re: WANTED
Hi Dean, Thanks for looking, hope you have one you can spare, cant stop the leak, one more try today but dont have a lot of confidence of success. Bob.H.
Re: WANTED
Hi Bob
No luck im affraid, the ones i have were given to me but are in a bad way.
Have a go on Frenchcarforum, its been confirmed that they are the same as xant ones so just ask on there for a Hydractive2 electrovalve.
There is plenty of traffic there and a good few people with spares.
bobhowes
Re: WANTED
Hi Dean Thanks for trying, will try the french forum as suggested, Bob H,
