XM parts
Southerneruk
Re: XM parts
I still have that pipe, I sure it is still fitted to the old engine that I replaced
Southerneruk
Re: XM parts
Just a test to see if got this right, but there are some of the parts I have
Re: XM parts
Thank goodness your first image didn't work...
The gear leaver, Hydractive Ecu and glovebox latch look interesting.
Do you have the ducting under the steering wheel for the knee vent?
Southerneruk
Re: XM parts
More than likely, when I pulled that car apart, I even kept the carpets, but some as all ready gone and some I have used
First image is too dark, but you can still see some of the stuff on there, like the panels
Macvettexm
- XM newbie
- Orga / RP numbers: Vf7y3axooooax6508
Re: XM parts
Front wiper motor..?Postage to Ireland. Thanks.
mellatyadak
- XM newbie
Re: XM parts
Looking for reliable body and engine parts for your Citroën Xantia XM?
You can purchase all type of XM parts in Middle east at spare parts store : Xantia spare parts
Restore your car’s performance and original character with high‑quality replacement components designed specifically for the Xantia XM. Whether you need engine parts to keep the motor running smoothly or body panels and exterior pieces to maintain its classic design, choosing the right parts ensures durability, safety, and a perfect fit. Invest in quality components and keep your Citroën Xantia XM performing and looking the way it was meant to.
