'A' pillar trims
Saraphi
Orga / RP numbers: 6834
'A' pillar trims
Post by Saraphi »
Both the left and right trims on the Silver Shark seem to be loose and the passenger side has been broken then cleverly repaired and has now broken again. there does not seem to be many if any clips or other fittings, they are held on with double sided tape (I now find) I'd like to replace them both but need a little guidance as to what I should be asking for.
You may recall that my car is or was an odd mix of bits from principally an S2 but with some trims coming from an S1. How can I tell which pillar trim is in the car? Looking at the Citroen Service parts they are both numbered 95 656 034 but the s1 seems to have 3 parts and the s2 only 2.
I don't want to start looking on eBay or advertising if I'm going to be getting the wrong thing........................
1995 XM S2 2.0i 16v - but with lots if Y3 bits
1995 Xantia 2.0 Exclusive
Re: 'A' pillar trims
S1 and S2 trims are the same, except S1 has more colour options.
You need to ensure you obtain colour option Hurricane grey (ZL).
Also be aware that for Sx and S1 ultra low spec cars a different p/n was used, but from Rp 76xx this was rationalised so only the lower spec ones were fitted, as the cars were generally downgraded in specification for the final two years of production.
Member, EthanR is breaking an S2, so may have these trims left.
It's worth obtaining the clips as well.
EathanR
Post by EathanR »
Hi,
I can check if I have them still tomorrow, and if I do can send you pictures over e-mail and a postage quote as have kept the details you sent before
