I have for sale some official dealer tool sets / cases if anyone is interested....
It's the ones in the large red briefcase-sized plastic cases.
9010-T.......XM front & rear hubs overhaul kit
9040-T.......XM & Jumper MG5T gearbox clutch overhaul kit
5711-T.......XM & Jumper DJ-DK engines overhaul kit
I also have a huge selection of Lexia / Actia diagnostic equipment / connectors / adapters / etc. Any interest ?
Alan.
Irvine, Ayrshire.
Dealer service tool kits & diagnostics
aramsay
Julianw
- Orga / RP numbers: 4937
Re: Dealer service tool kits & diagnostics
Is there any mileage in a group buy of the diagnostic equipment? This is the sort of thing that I pick up and squirrel away, but I doubt I'll ever make much use of it - I'd rather have a part share in it, know that it was available to me if I needed it, and could benefit everyone on the forum too...
aramsay
It's a good idea regards the diagnostic stuff. A single buyer might use an adapter once, but some kind of club "library"Julianw wrote: Sat Sep 05, 2020 10:29 pm Is there any mileage in a group buy of the diagnostic equipment? This is the sort of thing that I pick up and squirrel away, but I doubt I'll ever make much use of it - I'd rather have a part share in it, know that it was available to me if I needed it, and could benefit everyone on the forum too...
would be better for all. I got the diag stuff as part of a job-lot, so it doesn't owe me too much....
If it's any help, I'm down at Donington Park to watch the racing the w/e of 19/20th Sept. .... a bulk delivery would be possible between Ayrshire and there, within reason.
Any suggestions offers ?
I could list what I have.....there was too much for the post earlier.
Do you mean full working diagnostic equipment . . . an assortment of bits that could be put together to make full systems . . . or just all sorts of equipment/connectors/adaptors thrown in a box, some may work, some not?aramsay wrote: Sat Sep 05, 2020 4:05 pmI also have a huge selection of Lexia / Actia diagnostic equipment / connectors / adapters / etc. Any interest ?
I could be interested dependant on your answer.
- sageman
I would also be interested given the running issues I’m still having (and no codes showing on the blink tester)
1976 Reliant kitten
1998 Peugeot 306 GTI-6
1993 XM sei V6 RP 5876
Degens
Great idea to have it in the 'club' for everybody to use when needed. Happy to chip in if someone wants as it were to be the keeper of the things! Maybe we can do that with other stuff also!
If you have engine running issues and no codes are stored a diagnostic device won't help as it reads the same codes a Blink code reader does.sageman wrote: Sun Sep 06, 2020 5:28 pm I would also be interested given the running issues I’m still having (and no codes showing on the blink tester)
Detail your issues in a thread (not this one) and we might be able to help.
- sageman
I was hopeing a Lexia or other device would be able to tell me more
Am I wrong
Am I wrong
1976 Reliant kitten
Timcol
- Orga / RP numbers: RP 7183
Series 2
2.0 16v Sx
1997
Hi
I would be interested in a working lexia please pm me with details
Thanks
Tim
Thanks
Tim
The blink codes are very accurate and the same data the Lexia displays.sageman wrote: Mon Sep 07, 2020 7:08 am I was hopeing a Lexia or other device would be able to tell me more
Am I wrong
The Lexia/Proxia is just a graphical interface for the Ecu's.
You will be able to see live data displayed, so can see sensor outputs instead of having to use a meter to measure them.
A wiring diagram and Dmm is as useful as a Lexia.
All sensors can be diagnosed using a Dmm, only the O2 sensor being a bit tricky due to refresh rate. You can still test this by manually triggering the Tps to give a rich mixture.
You can perform tests and actuations with a Blink code reader.
I would spend money on a scope before the Lexia.
Start a new thread, or find your existing one and update it.
