Speedline bolts
Lwdajo
Speedline bolts
Post by Lwdajo »
Hi All,
Does anyone have a set of wheel bolts for a set of Speedline alloys, or advise me exactly what length of bolt I need?
I understand I need flat with washer.
Do Citroen still sell these? Probably far too expensive if they do, but it seems to be a bit of a minefield on ebay, so if anyone can recommend where to buy from, that's another option.
Thanks,
Lee
Lwdajo
Re: Speedline bolts
Post by Lwdajo »
Also, does anyone know someone who can do a good job at refurbishing alloys close to Leicester?
Regards,
Lee
Re: Speedline bolts
Post by MTXM »
I may be able to help you with the wheel bolts Lee and I will have a look tomorrow. With regards, Matthew T. PS. I posted the cap on Saturday.
Re: Speedline bolts
Lwdajo wrote: Mon Jun 10, 2019 6:19 pm Also, does anyone know someone who can do a good job at refurbishing alloys close to Leicester?
Regards,
Lee
Belmont metal finishers at Old Dalby do an exceptionally good job. They even tape the rims when fitting the tyres back on.
https://www.belmontmetalfinishing.com/default.html
Lwdajo
Re: Speedline bolts
Post by Lwdajo »
Thanks Matthew in advance for the bolts and I've got the cap, thanks.
Thanks Will, I'll give them a ring.
Lee
Lwdajo
Re: Speedline bolts
Post by Lwdajo »
Hi all,
I'm hoping to put my wheels in for refurb tomorrow, but I still have no bolts!
There are a couple of you kind people checking stocks, but reposting in case anyone else has any or can tell me the spec of the bolt.
Thanks,
Lee
Re: Speedline bolts
Let me check my stocks tomorrow. I've had a few. More. Come to light recently..
Lwdajo
Re: Speedline bolts
Post by Lwdajo »
Thanks in advance for looking.
Steinkul
Re: Speedline bolts
Post by Steinkul »
Hello, bolts for XM' s alu are seized all the same.
Re: Speedline bolts
Had a look at the stack of bolts.. I've 4 spare but also 4x shorter bolts too.. Heads are the same just the thradded part is shorter..
I'm sure there is more there..
