series 1 Xm td parts wanted
ststech1973
Orga / RP numbers: xm 2.1td sed 1992 rp 5566
Post by ststech1973 »
I I am in desperate need of some parts.
Short coolant hose goes from top hose outlet round side of engine about 8-10 inches long
Mine has developed a pin hole.
Also looking for lower speedometer cable from gearbox to the speed sensor pictured which sits by lhm tank.
Also looking for heater semi auto air conditioning ecu pcb
it is the semi auto has 3 dials with auto fan speed and seperate ac cut switch on dash and recirc manual slider on the right
also need a heater dial as one broken and recirc slider knob.
Electric centre console rocker switch locks like a window switch and sits in centre console switch bank.
Drivers side front fog/indicator unit as my fog lamp lens is cracked.
Any help much appreciated
Tia Simon.
2012 ds4 d style 1.6 hdi 110 silver
2007 c5 2.0i 16v exclusive auto (sorn)
2007 c6 2.7hdi exclusive mauritius blue (sold)
2007 c4gp 2.0 hdi egs exclusive
Re: series 1 Xm td parts wanted
Can supply most centre console rocker switches but not quite sure which one you need.
PM me with name and address and will post.
There are some recovered dials about but most are complete auto pcb's.
ststech1973
have sent pm 4 times but stays in outbox so have sent email also
regards Simon
They all arrived.
The website is playing up.
Have replied.
Keep this thread updated as to what you need. I will have it all, but need to dig bits out/remove them from my car.
ststech1973
i have located an armrest switch
just need the rest plus my gear knob that i previously glued up crumbled in my hand yesterday in the heat so looking for an xm gear knob also.
TIA Simon
ststech1973
have bought a gear knob off the bay £6 and fabricated a new coolant pipe from a scrap C5 1.6 hdi bottom hose :)
getting really desperate for the heater control panel if i could find the ic i need i would repair the one i have but it is not available anywhere
someone must have one they could sell me :)
markviney
Post by markviney »
Hi,I have a NOS control panel,part number 95659374 which may fit your xm listed as heating and
Regulation heating from rp 4883 on service box.This is a valeo unit in box,any questions then please pm many thanks mark
ststech1973
i have emailed and sent a pm
regards Simon
