Hello
I've got a problem with clutch cable I need to find one but it's a left hand drive car probably clutch cable from uk car it's not gonna fit, like I heard some people are making them somewhere maybe someone know where I can find it ?
Citroen xm 2.1TD 1997y Y4
I'm going to restore that car too original condition I will need some different parts as well but first of all I need to keep it running
Thank you in advance I'm living in Derby
Citroen Xm 2.1TD Clutch Cable
Re: Citroen Xm 2.1TD Clutch Cable
Welcome!
Could you post your VIN number, and that will help the search.
Mirol201
- XM newbie
VF7Y4GZ0001GZ0908 there You go I hope is gonna help by the way it's a polish car
OK, LHD manual, engine XUD11BTE.
RP number = 7665, which means it left the factory on 3 November 1997.
Part number for the clutch cable is 96 118 754, Length = 830mm
Item from Citroen is NFP (discontinued), as you'll already know.
You might be able to find one by doing a search on the web (if not done already), or someone here may be able to help.
A company which can make up new cables is http://www.speedycables.com, who are based in the UK, in Swansea in South Wales.
They have a long a good reputation.
You could contact them and discuss; they may or may not need your old cable as a pattern.
Mirol201
- XM newbie
Great thank you so much for help, I was trying to find that on web for at least year unfortunately I didn't find any of them.
I will contact that company we will see if they can help me somehow
A local ropes and lifting equipment supplier should be able to crimp a new inner cable for you, failing that try Speedograph Richfield in Nottingham
http://www.speedograph-richfield.com" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Here is one in germany.
https://www.citropart-shop.de/Ersatztei ... sseil.html" onclick="window.open(this.href);return false;
Mirol201
- XM newbie
Thank you dieselman I will give them a try,
