Dipstick
Lwdajo
Dipstick
Post by Lwdajo »
Hi All,
Does anyone have or know where to source a dipstick for a 1994 2.1TD Mk2.
I've just realised the top on mine is broken and taped up to stop it dropping into the engine.
Alternatively, if someone can tell me the size, as I don't know if mine is even the original.
Thanks,
Lee
jamescarruthers
Re: Dipstick
Post by jamescarruthers »
You could still get those from Citroen recently. Or fix with a cork!
1987 Volvo 480 ES
Previous XMs:
H656 BKJ XM 2.1 SED
djg
Orga / RP numbers: 7903
Re: Dipstick
Post by djg »
Gardena hose end. A picture must be somewhere here in the forum.
The search helped: viewtopic.php?t=6763" onclick="window.open(this.href);return false;
Bye,
Gábor
Lwdajo
Re: Dipstick
Post by Lwdajo »
Thanks folks,
You were right - special order from dealer, but still available, around £20.
I did find the picture after searching, but unsure if the dipstick is original, so wasn't confident to do a Gardena repair!
Cheers,
Lee
