Power Steering Pump
Shaun17
Power Steering Pump
Hi Iwould like to get a Power steering pump seal kit..Or does any body know the size???? thanks
Re: Power Steering Pump
I take it you mean the hydro pump.
As yours is a Non-sinker, it has the later 5+2 pump. Which seals are you after, the nose seal, or the output O rings?
Shaun17
i don't know which seal All I know is Citroen Used to do a kit for it...
They rarely leak at the nose seal, so it's likely that all you need are the high pressure union O rings.
Shaun17
Do you know what size they are.????
2 x 402687 - 16 TO1.9
1 x 402688 - 19 TO2.4
nose seal: 1 x 402686 - 44.2 T3
