parts
Shaun17
parts
Post by Shaun17 »
Has anybody got the following for my 96 2.5 td VSX XM. Offside front lower engine mount. Power Steering seals and the reservoir water tank..Thanks Shaun
Re: parts
Where are you located?
I know of a 2.5 being scrapped in E mids.
Shaun17
Re: parts
Post by Shaun17 »
I am in Sevenoaks Kent...
Shaun17
Re: parts
Post by Shaun17 »
thanks Dieselman I will give I will give him a ring tomorrow...
Re: parts
Be sure this work is needed.
There is no bottom engine mount on a 2.5TD.
Top and bottom ones are very soft rubber buffer stops.
They allow the engine to rotate back and forth 40 to 50mm either way.
Much more movement than a normal engine.
Exhaust has a flexy section for the extra movement.
There are just two axial engine mounts either end on the centre of gravity of the engine and box.
The top and bottom buffers are routinely replaced without need because the engine suspension method is not understood.
Shaun17
Re: parts
Post by Shaun17 »
THanks xm I wii call my garage on Monday and explain it to them…….That does make sense…..
Re: parts
Water header tanks for 2.5 TD were available new from Citroen a couple of years ago.
If obtaining S/H one then check that the red internals are still good and complete.
These bits control internal water flow direction and also mark fill level.
Shaun17
Re: parts
Post by Shaun17 »
Shaun17 wrote:thanks Dieselman I will give I will give him a ring tomorrow...
Thanks Diesel man I got my parts from Greg Bibby They should arrive Tuesday….thanks again….
Re: parts
Good to hear.
beckyrachel
Re: parts
Post by beckyrachel »
Anyone got a number for Greg Bibby - I need 2.5TD parts.
