WANTED: PRV6-24 air flap electrovalve
The solenoid valve for the long air flap control. p/n 036338.
Mounted at the rear of the plenum chamber near the drive belt side, under the vacuum modulator.
This is the same valve fitted to the 2.5TD to control the EGR vacuum.
Re: WANTED: PRV6-24 air flap electrovalve
BUMP.
I'm still after one of these, ideally before I remove the plenum chanber and rear bank of injectors.
Anyone got one?
