1995 Xantia TD LX £125 or offer
Post by White Exec »
There's a rather tidy Xantia, located in Reigate, which has appeared on FCF.
XUD 1.9TD manual
MoT issues, but eminently fixable, by the look of it.
Looks far too good to scrap or break.
Owner wants it shifted soon.
Details here:
https://frenchcarforum.co.uk/forum/view ... 11#p550800
Re: 1995 Xantia TD LX £125 or offer
The LHM leak sounds like the strut return pipe...30 minute job start to finish, and £10.
That's the best version of Xantia, first facelift, with improved headlamps, but the original grab handle dashboard.
EDIT:
Just checked the MOT fail notice and it's somewhat more comprehensive.
Date tested 18 September 2017
Fail
Mileage 97,921 miles
MOT test number 3388 2948 3493
Test location KSM AUTO CLINIC
HOCKLEY HOLDINGS
HOOLEY LANE
REDHILL
RH1 6ET
Reason(s) for failure
Offside Front Anti-roll bar linkage has excessive play in a ball joint (2.4.G.2)
Offside Rear Fluid suspension unit interconnecting pipe corroded and seriously weakened MARKED (2.4.D.3)
Fluid suspension leaking offside front (2.4.D.2)
Offside Rear Suspension component mounting prescribed area is excessively corroded inner sill area MARKED (2.4.A.3)
Offside Front Steering system has a tyre fouling a part of the vehicle rubbing badly on offside front handbrake cable (2.2.D.2a)
Service brake: efficiency below requirements (3.7.B.7)
Advisory notice item(s)
nearside wiper starting to split
both front tyres heavily cracked and perished
front brake discs heavily corroded/lipped/scored
offside rear tyre heavily cracked and perished on inner and outer sidewall
rear brake discs heavily corroded/lipped
rear exhaust silencer heavily corroded and slightly leaking
offside rear brake back plate/dust shield missing
nearside rear brake back plate/dust shield corroded/slightly inscure
It's not worth it to fix it to pass on, but as a keeper it's worth doing, especially if one can weld. It needs one patch and a day spending on it.
I see there is interest in Congleton. Transport costs would be about £200, maybe a bit less.
raynoon
Orga / RP numbers: 6043
Post by raynoon »
Lovely colour
