Inner Tri-ax boots
citroenfa
Orga / RP numbers: 5091
Inner Tri-ax boots
Post by citroenfa »
Does anyone know of a source for the inner tri-ax boots for a Series 1 XM with a V6 (12 valve) engine and Auto Trans? All the ones I have seen on-line are too small. The inner opening (trans side) needs to be 100mm. Additionally does any one have the special spacers and rubber buffers for the inside of the front suspension struts? One of mine is just about gone and for some reason the spacers are missing - I suppose due to far to many hands having worked on this car over the years :).
Take care,
Steve in Los Angeles.
1972 DS21 BVH Pallas, 1969 ID21 Break, 1985 2CV Charleston, 1992 XM V6 Auto - good grief 1989 AX :) Enough Cits...
Re: Inner Tri-ax boots
The Citroen p/n is 3287.72.
Interchange Parts for CITROEN 3287,72
Brand Sku Type Name Relevance
MEYLE 40-14 495 0016 Drive Shaft Bellow
QUINTON HAZELL QJB 633 Drive Shaft Bellow
RUVILLE 756662 Drive Shaft Bellow
SASIC 2873723 Drive Shaft Bellow
TRISCAN 8540 28914 Drive Shaft Bellow
CITROEN 95 653 008 Drive Shaft Bellow
PROTECHNIC PRB207 Drive Shaft Bellow
CORTECO 328772 Drive Shaft Bellow
CORTECO 328772B Drive Shaft Bellow
KAGER 13-0133 Drive Shaft Bellow
FIRST LINE FCB2649 Driveshaft Bellow
TRISCAN 854028914 Drive Shaft Bellow
AUGROS 5217942Q Drive Shaft Bellow
CITROEN/PEUGEOT 3287.72 Drive Shaft Bellow
TRIPLE FIVE 99 1445RU Drive Shaft Bellow
PEUGEOT 5175.J0 Drive Shaft Bellow
PEUGEOT 95653008 Drive Shaft Bellow
SPIDAN 26282 Drive Shaft Bellow
