wanted cheap citroen xm 2.1 td and fuel pump
patrickm
XM newbie
Post by patrickm »
hi,am after a very cheap 2.1 td xm or just an engine with bosch fuel pump,or just a bosch fuel pump for a 1993 sd turbo dont mind state of whole car as just need these bits.thanks
jonathan_dyane
Re: wanted cheap citroen xm 2.1 td and fuel pump
Post by jonathan_dyane »
If you can't find an XM Bosch pump, it might be easier to find a Bosch pump off a 1.9 TD Xantia, and just turn the fuelling up a bit.
Jonathan.
2004 Saab 9-5 Aero Estate
1999 Yamaha FZS 600 Fazer
1991 Kawasaki GT-550
1986 MZ ETZ 250
Assich
Orga / RP numbers: 5678
Post by Assich »
You want to check on costs for a recon as they are not as expensive as you might think. Local engineering shop that does that sort of thing is where to go.
1992 build 2.0i Prestige Auto
