Does anyone have any of the flat washer type wheel bolts, suitable for Series 1 alloys, spare?
I have 12 bolts with the 44mm threads so need another 8 to make up a set.
Are locking bolts/studs available for these wheels?
I do have eight bolts with 36mm threads, but understand these to be too short. Can anyone confirm that is the case as I don't have the wheels here at present.
EDIT:
Having checked the amount of protruding thread when inserted through the spare steel wheel (with the additional thickness bushes), there is plenty of thread available with either bolts and slightly more than my other car bolts as supplied by the manufacturer.
So the question now is, do I need all the bolts to be long bolts at all?
Wheel bolts
Wheel bolts
Re: Wheel bolts
Hi Dieselman
Are they the ones that I sorted out.
Never noticed they were different lengths.
Strictly you only need the long ones.
Wheel centre is cast thicker if it has a hub hole.
The others are from MonteCarlo solid centre wheels.
Decide what you need and let me know.
Re: Wheel bolts
Hi John,
Yes these are the ones you gave me.
I need eight longer bolts if you have them.
TIA.
TIA.
robertmnorton
Re: Wheel bolts
Hi Dman,i'm probably a bit late now,but have found 7 alloy wheel bolts in a box amongst other collected bits.The shank length from underside head is 46mm.If you still need them i'll post them out.
robertm
robertm
Re: Wheel bolts
Hi Robert.
If these are the type with a flat washer under the cap, then I would appreciate them. I think John is going to have a look when he can, but I appreciate we don't always have time immediately.
I want to get he wheels fitted as soon as they are ready.
I'll PM you my addy if these are indeed the correct bolts.
robertmnorton
Re: Wheel bolts
Hi Dman,yes that's them,i still have your addess so will put them in the post soonest.
robertm
robertm
Re: Wheel bolts
Hi Dm
Glad you got sorted.
Re: Wheel bolts
Hi John.
One down still if you have one spare.
Re: Wheel bolts
Will try to remember to look one out.
